Upgrading to big turbo. 2020 Si. Any tips before I replace it?
Ronny2019
Ron
Long Island New York
2019 Si Coupe
Ducota
Ron
2020 Civic Si 2021 Accord Sport 2.0 2015 FiT Sport
Doc_Mello
2019 CBP Si Coupe
LBP
I swear I must be the only person that had no issue with dropping the inlet bolts without special tricks or tools, but had enough trouble locating the socket onto them to make up for it. Those lower bolts took me WAY too much time the first go-around.
madchiller
Chad
DFW, TX
2018 Civic Si
being the prl junkie that i am. would that turbo blanket also fit the prl big turbo kit with the 2860gen2 turbo? or should i buy the one off amazon?
basically prl x ptp or just the ptp? they look quite different and the ptp version seems it would fit around the turbo vs just laying on top it.
I would suggest a turbo blanket. For me it helps with intake temps tremendously. Good luck
VargasTurboTech
Anthony
vargasturbo.com
2019 SI MT Sedan, 2020 A90 Supra, 2021 BMW M3C...
Xw-40 is so thick....my main concern for the future
This is the viscosity you need when asking turbos to run high boost pressures with high thrust loads. We do not recommend anything under 5W40 or 0W40 for upgraded turbo builds...
ChefRyeSi
Ryan
Rhode Island
2018 Civic Si Sedan / 04’ CRV EX 5MT
I completely get that. What’s been your findings as far as oil flow along with that flow in colder climates?
Ronny2019
Ron
2019 Si Coupe
Not sure but i belive prl has a blanket for that turbo special
madchiller
Chad
DFW, TX
2018 Civic Si
nah, they didnt have a prl branded one like the ones for the stock turbo. i ended up getting the PTP FPRO35-028-01 blanket that fit well over the 2860gen2. i still have to replace the ewg bracket but the new one they sent is made out of stainless steel which should resolve any future breaking.
the downpipe is cerakoted but im thinkin of having it wrapped but im really unsure at this point.
Honda Civic 10th gen Upgrading to big turbo. 2020 Si. Any tips before I replace it? 1671902746755
Ronny2019
Ron
2019 Si Coupe
Dont think that wrapping the dp is that great of an idea but to each his own. Good luck looks great
