hobby-man
- Mike
- Jun 20, 2018
- 50
- 2,867
- 2,739
- GTA
- 2021 WRX STi, 2018 Sport Touring Hatchback (sold)
- Build Thread
- Link
I totally get doing it just for the looks I'd do it too haha. I wasn't aware of the possibility of coolant tanks rupturing so good to know it's also functional if you track.My sole purpose was to clean up the engine bay and get that plastic tank out of the engine bay.
However, I have seen a few instances where the fk8 has had ruptured plastic tanks at the seam in race applications.
I'm aware this is not for everyone but those that are interested can make this work in the non R platforms.
This is from Radiums page:
Because of continuous and intense heat cycling, plastic coolant tanks have a reputation of failing over time. Fortunately, the rugged 2-piece Radium Engineering replacement is CNC machined from aluminum and anodized for increased longevity. And because aluminum is a superior thermal conductor material, heat transfer is further improved. Additionally, the metal construction is robust enough to use in racing applications.
This FK8 Type-R kit directly replaces the plastic Honda tank without making permanent modifications to the vehicle. A specially designed mounting bracket secures to existing threaded holes and Radium adapter fittings interface with the factory lines. The tank functionality remains the same as the OEM cooling system.
NOTE: Laser engraving and fitting color may differ from what is shown in these pictures. Contact Radium Engineering for more information.
The Radium Engineering Coolant Expansion Tank has proved itself over the years in many applications all over the world, in race and street vehicles. The internal volume of the Radium Engineering Coolant Expansion Tank is equivalent to the OEM tank resulting in no coolant loss. The internal design features two chambers with cross-over passages at the top and bottom. The coolant tank also has an internal swirl feature aiding in deaerating the system.
NOTE: The OEM 1.3 Bar Honda pressure cap can be re-used.
