bobafettm
- Jan 8, 2017
- 12
- 733
- 844
- Metro Detroit, MI
- 2006 Lotus Exige; 2018 & 2021 Honda Type R
*EDIT* I've taken @ctrmofo detailed guide and updated this thread for future reference. Thanks again CTRMofo! Use his friends and family discount code for 12.5% off your order directly with blendmount (cheaper than amazon): http://blendmount.refr.cc/ZBWKHQL
Radar Detector Installation Purchase List:
1) blendmount bmx-2000r if you're using the max360 detector. specific model based on your detector. our mirrors are the same stem of course.
2) blendmount direct hardwire 8 ft (has inline 2a fuse)
3) blendmount wire cover to tidy things
4) ATM-LP (low profile) add-a-circuit and ATM-LP fuse (minimum 2a or a dummy jumper fuse...since the blendmout hardwire has an inline 2a fuse which will be your main fuse for the detector circuit) both of which can be picked up at local autozone for cheap
5) option 1/4" black flex loom
Radar Detector Installation Guide:
1) follow installation guide from blendmount included in the box and make sure to NOT tighten the top collar bolt until the very last step.
2) run wire along top edge of headliner - very easy since there's a gap already. leave enough wire length at the mount so you can plug/unplug detector.
3) remove small cap on left a-pillar marked "airbag" and remove one silver screw.
4) pop out a-pillar panel which has 1 clip toward the bottom.
5) continue to run wire along a-pillar and BEHIND/UNDER the airbag - NOT on top of it.
6) at the section of dash with about 10" vertically, use optional black flex loom to wrap the wire - reason being to not have any wire rattle that may occur. jam the flex loom in that 10" gap and hide.
7) continue running wire down to fuse box under dash on driver's side.
8) find fuse location #1 labeld "ACC" for accesories showing 10a fuse.
9) unplug the 10a fuse and plug into the ATM-LP adapter in the slot without the red wire. plug a new ATM-LP fuse (at least 2a) into the other slot with the red wire.
10) crimp/connect the ATM-LP adapter's red wire with the red wire from the blendmount direct wire.
11) plug the ATM-LP adapter into fuse slot #1.
12) ground to the silver bolt on the fuse box located at the corner.
Tidy up your work with black zip ties and black electrical tape for a nice look. be sure to leave the inline 2a fuse exposed in case you need to replace it for a reason.
