TegGSR2CivSi
- Feb 7, 2018
- 2
- 8
- California
- 2017 Civic Si Sedan
TL;DR: Does the Gen 10 MT Civics coast too much and lack engine braking while in gear?
*disclamer* This is not a thread to debate if engine braking for your car is good or bad or a brakes v. clutch and rev matching discussion. I'm going to assume we're driving down a really steep ass hill and the brakes should have been replaced, so we need the engine's help */disclaimer*
I just recently got a 2017 Civic Si after driving a 97 Integra for 12 years.
After driving my 5-speed for so long, I'm incredibly used to my 'Teg engine braking IMMEDIATELY when coming off the gas to the point that I could get substantial life out of my brakes. But in comparison...
I'm finding the Civic to drive half like a manual and half like an automatic... fun to accelerate in and shift gears with, but HORRIBLE to slow down in....it feels like in gear it's actually coasting like an AT. Going down hills at highway speeds is pretty sad too. With my foot off the gas and being in gear, my integra can slow down in 5th from 80 to 60 in probably 10-15 seconds. The Civic in 4th gear, even, either slowly picks up speed or just barely holds constant speed. What gives? Is this transmission gearing or how the engine is working?
I noticed the Civic also has substantial 'rev hang', and there's a bunch of threads on how to tune your car to reduce the 'rev hang' and make your car go faster.
...Can you also tune your car to, essentially, go slower?
After doing a little half-assed, two-beers-in research, I believe the ECU or MHEC (magical honda engine computer) while at speed leaves the throttle full open while you take your foot off the gas and leaves the injectors spraying next to nothing, eliminating compression? Did I read this right? Is there a way you can reprogram your MHEC to make engine compression when no throttle input detected!
At the end of the day, would it be possible to tune a Civic to drive like a non DBW throttled manual? Or are things like Hondata and KTune only for improving going forward stuff?
