totopo
- Apr 3, 2016
- 2
- 344
- 307
- CA
- '17 Civic Ex Hatch, 370z
The actual angular roll of the car doesn't change, it is sprung and the diameter of the tire doesn't really change. What you are probably feeling is either the extra lateral translation and the car "falling over" the contact patch, or the tires are generating more grip and so you get more roll.Yep...
I will disagree with you that a tall sidewall does not translate to more roll... though I'll agree it is essentially separate from the sprung weight laying down in cornering. Your suspension is based around your OEM wheel/tire size. Change nothing but the wheel/tire combo... going down on wheel size and up on the sidewall keep the overall circumference the same while retaining essentially the same tire width to... your body roll will definitely increase. I can flex a sidewall with my bare hands... but I haven't spent enough time in the gym to do the same trick with steel/aluminum wheels. Take a hard corner on a tall tire... not only does the body lay down on it's suspension, it'll squish down the taller sidewall on the outside wheels, and the tires will actually bend with the road... magnifying the effect.
Going wider definitely helps hold the tires from flexing so bad.
I have got 2 sets of rims for my Z... running the stock 225-50-R16s and I got some late model 350Z running 245-40-R18s (pretty much all I run anymore). The car definitely has more roll with the higher sidewall 16s. Same experience when I went back and forth between the 16s I had all seasons on and the 18s I had summer tires on the RSX. Far more body roll. Yes... both are wider tires too which is a huge contributor.
The article I posted was an old thing I remembered and, it is ashamed they couldn't maintain tire width constant as a control... but it's what I remembered having seen way back when.
Here's a decent vid of sidewall flex on a car in motion...
Unfortunately I can't find a comparo video really... showing something like a 16 vs an 18 with the tire having the same circumference and same width.
Sidewalls definitely flex, that is what tires do and how they generate lateral traction. But narrow tires and less sidewall don't always mean more traction like it used to I think. Not a tire expert, but these days doesn't seem to be a big factor. Kind of like camber and anti-roll bars. Things drivers love but doesn't translate to much difference in track times.
