DIY Brake Fluid Flush with Motive Pressure Bleeder
ez12a
CA
18 CW Type R
Just did this maintenance this past weekend. Hope this quick video helps someone!
Clutch Slave Flush supplemental video:
Patrick Bateman
‘18 FK8, ‘19 XC60 R-Design, ‘17 ZL1, ‘02 SS
Nice. I’ve got that bleeder.
Few questions..
Where’d you get the reservoir cap?
Are you sure about the order you did it in? I’ve always worked from the furthest caliper to the reservoir to the closest.
ez12a
ez12a
CA
18 CW Type R
Few questions..
Good questions!
Link to the cap is in the video description. Should see it if you open the video in YouTube.
For the sequence, it is correct. Attached is a pic from the service manual.
Honda Civic 10th gen DIY Brake Fluid Flush with Motive Pressure Bleeder Screenshot_20200531-142243
Patrick Bateman
Good questions!
10/4
Thanks
Tev42
Tyler
San Diego
2019 CTR
Good questions!
Thanks for posting this. Planning to do this in the next few weeks
Centripetal
Boston, MA
2006 RSX Type S, 2017 Civic Type R
Few questions..
I modified a CTA Tools 7030 Master Cylinder Adapter-Honda so I could hook it up to a compressor with pressure regulated down to 15-20 psi . Way better than speed bleeders. It made the pedal feel on the the clutch and brake so much better on every Honda I've used it on.
MadMage
Dan
Arizona
2020 Type R
@ez12a The brake bleeding video is no longer available on YouTube. Might you be able to repost it or fix the broken link? Thanks!
ez12a
ez12a
CA
18 CW Type R
Thanks for the heads up! Weird, i wonder if it changed the URL when i updated the title. Fixed now.
GraphiteAZ
Tucson, AZ
With the motiv - are you adding fresh fluid to it or to the brake fluid reservoir? Sorry, I've only ever bled brakes the pump and hold method with a person helping.
ez12a
ez12a
CA
18 CW Type R
In my video for brakes I add fluid to the motive so I don't need to worry as much about topping off the reservoir.
In my second video for the clutch I just use it while empty to pressurize the reservoir.
hobby-man
GTA
Interesting, I wonder why they recommend starting with the caliper closest to the master cylinder?
