chadwicke619
- Chad
- Feb 21, 2022
- 21
- 104
- 47
- San Diego
- CBP 2021 Honda Civic Type R
- #61
Alright, cool dude! Thanks! This is kind of what I was thinking - just accept the largely-negligible unevenness of wear that I'll experience before I next put the car up, but clean the fronts. At least I can take the easy route and I don't need to put the car all the way up again (not that I "needed" to do it that way before, but you know what I mean).Yes, performance pads tend to be flat. Even our OEM front pads are!
Well, I wouldn't bother with the rears for now, but I definitely would clean off the front pins. Grease near brakes is never ideal, maybe it could melt and drip onto the rotor/pad surface. I sometimes make a mess when greasing the rear sliding pins and then I need to use a brake cleaner on my rotors to remove any grease spots.
You probably noticed the rear sliding pins have a plastic enclosure with a cap. That is needed to keep contaminants (like brake dust) out of the grease. A good rule of thumb is that you usually shouldn't grease any spots open to contamination. But don't worry with the rears for now, next time you have to inspect your rear pads you can grease those pins.
