@KramVT0215 has a custom tune from Vit that peaks at +25/26.. similar to the stage 1 tune, but he had to dial it back to the 19/23 staged map because of clutch slip.I want to know as well. I’ve read you don’t need one with a stage 1 tune, but some members have had their clutch slip with that tune. One member had his clutch slip on a highway pull. Planning on getting a k tuner with vit stage 1 tune this year.
I would like to know if anybody is using KTuner's starter 19 or Hondata's +6 only and whether or not they're slipping off the OE clutch.I frequently see on these forums users mention that their clutches are problem free for 1-2 months and then the clutch begins slipping after that. The way I see it, the stock gen X Si's performance already puts a smile on my face and I love the reliability. The slight performance bump from tuning is not worth the wear as far as I am concerned. Granted, I am more of a set it and forget it kind of guy- I am not in my garage 24/7 tinkering. If you do plan on tuning you should plan to get a better clutch not too long after.
I read somewhere that the fx300 should last longer than the fx350.Did the fx300 take care of the slip? I know the 350 is popular, but I’m not going for crazy horsepower. Just a reliable clutch to last for a long time with a stage 1 tune.
How much did the install cost you?I used 17 psi normal / 21,5 sport mode tune with prl cobra street intake, prl catted downpipe, prl front pipe
I rarely used sport because my clutch would slip a lot. I had highway pulls with my clutch slipping on 17 psi with everything factory except aggressive 1 on turbo ramp up
so i ended up with an fx300. My oem clutch is currently in my garage and it still has a lot of "meat" on it.
Vit's 19.5/25 tune does not boost the turbo pressure to 25 psi and cause clutch slip! Only the driver is the one that does that. Vit only raises the limit. Nobody is forced to go to the limit. Good drivers don't lug the engine. They don't tell the engineers to make it impossible for them to lug the engine. From what I gather clutch slip is usually from boosting the pressure past 20 psi in a higher gear below 4000 rpm. Just don't do that and maybe you will be fine. If you want to play around with 25 psi boost then do it in lower gears and in higher gears above 4000 rpm.
