dick w
- Oct 25, 2015
- 11
- 1,985
- 877
- Kapaʻa, HI
- '16 Civic Sedan Touring, '18 CR-V Touring AWD
My question is: what diagnostic info is available via the Honda i-HDS scan tool to diagnose operation of the auto climate control in specific and the AC in general? The climate control in our '16 Civic seems like it is not working as it did for years and I'm having a tough time getting the dealer to figure it out and get it solved. The problem is that it's taking a *long* time to cool down the interior when it's hot--like sitting in the sun for hours hot. It doesn't seem to be doing all it can do--or used to do--in terms of air volume (fan speed) and cold air output even when the interior is a lot hotter than the temperature set point. So, I'm wondering if the scan tool can tell what temperature it's sensing in the interior, what it's sensing from the dash sun sensor, what portion of available AC compressor displacement it's commanding, etc. The problem is that it is working at least a little bit, so it's pretty easy to blow off our reported issue. Dial the set points down to Lo or 60, and the air volume does go way up and the temperature does drop faster. I'm not clear on why it works so much harder to get to Lo or 60 from, say, high 90s in the interior, than it does to get to, say, 72.
Two additional data points from the vehicle's history. First, in the spring before we started observing this AC problem and before the weather and our use pattern was creating the conditions where it is readily apparent, it had its "Wire Harness, Engine Room - Honda (32200-TBA-A80)" replaced due to rodent damage. Without access to the Honda techinfo, I don't know what all subsystems that touches. Second, on its first visit for this complaint, they reported finding a leaking AC condenser which they replaced under the warranty extension for the condenser. Our observations were that this repair did not change its behavior. So, maybe a leaking condenser was a problem, but it wasn't *the* problem.
