hobby-man
- Mike
- Jun 20, 2018
- 50
- 2,867
- 2,739
- GTA
- 2021 WRX STi, 2018 Sport Touring Hatchback (sold)
- Build Thread
- Link
Hey all, I'm fairly comfortable working with electronics but not so much at designing my own circuits so I was wondering if anyone has any input on this. Right now I'm running two accessories off of one +12V switched ignition add-on fuse tap sources. There's a possibility of adding more in the future, so I think it would be smart to just put together a +12V switched fuse box, and run any accessories off of that instead. I think the way to do this is with a relay. My basic idea is below.
Use the +12V switched accessory fuse as the trigger for the relay. System is off until ignition is on.
Once armed, power flows from the battery through the relay to the fuse box.
Individual circuits off the fuse box are still switched, so load will not be instantaneous.
Questions:
Any ideas or suggestions appreciated!
Questions:
- Does this even work/make sense as described?
- Is a 30A inline fuse required for the relay if all the outputs are also fused?
- Is a 30A inline fuse enough given the specs of the fuse box? There would never be a situation where all circuits are fully loaded, and certainly not at 30A per circuit. But better to be over than under protected?
