hal9000
- Dec 14, 2015
- 2
- 115
- 120
- Upstate New York
- 2016 Civic EX-T
- #16
So the shift knob went as expected..very easy.
Tools needed:
Phillips head
Thumbnails
Time 10-15 minutes
On the select lever there's a silver trim ring between the knob and the boot. On the ring are two raised indicators. If viewed from above they'd be in the 3 and 9 o'clock position.
Directly below these indicators hidden inside the boot are two tabs on the base of the knob. These basically hold the silver trim ring up.
Feel through the boot and locate the two tabs. Pinch both tabs with one hand while pressing down on the trim ring with your other hand. The trim ring will slide down. You can see in the first picture how the trim ring is separated. The bottom mounting screw is now exposed.
Next you're going to remove the black plastic cover plate from the front of the knob. It's held by two tabs located near the bottom of the cover. This picture shows the location of the tabs. This is where you'll want to place your thumbnails.
Insert a thumbnail on each side between the cover and the knob. Gently push forward towards the dash.The cover will pop off. The top mounting screw is now exposed. Here's a shot of the tabs inside the cover as well as the two mounting screw holes on the knob.
I used a stubby Phillips head to remove the two screws holding the knob on. Once the screws are removed the knob will simply slide up and off.
From this point everything is basically the reverse.
Add new knob and reinsert screws.
Pop plastic cover back on.
Slide silver trim ring up until it clicks in place.
Tools needed:
Phillips head
Thumbnails
Time 10-15 minutes
