n9yty
- Steve
- Feb 28, 2018
- 20
- 199
- 61
- USA
- 2019 Honda Civic Hatchback EX
Thanks for this... I remember seeing this same recommendation a while back when I was looking at putting different bulbs in my 2002 Civic... But I kinda forgot about it.The most cost-effective solution to better light that I've found (and can be done with a low amount of mechanical skill as long as you're handy with a craft blade and nippers) is to put H9 bulbs in the stock low beam projectors in place of the awful H11s and 9011 (HIR1) bulbs in the high beam reflectors in place of the mediocre 9005s. You get probably 3/4 the performance of HID, at least in our stock lights, for under $30 if you shop around for the bulbs. I drive Lyft on the side ~20 hours a week in all conditions, chiefly at night, and the halogen bulb swap was the best bang for the buck under $100, imho.
Any recommendations on what brand/type to get? I see the Philips rated higher on Amazon than Sylvania, but they all have plenty of reviews about a very short lifespan. And can you go with just the bottom-end of the product line and still have it be worthwhile? At least they have longer lifespans. Burn so bright, die so young, as they say.
But I guess even a bottom-end H9 should be an improvment over the stock H11, right?
I'm not against spending the $30-$40 versus the $10-$15 really, but if reports of <8mo lifespan is typical, then for my needs it may not be worth the 3x to 4x price increase for an inverse lifespan.
No concerns over putting a higher wattage bulb in there, either for melting the housings or overloading the wiring? Again, stock 2019 Civic Hatch EX... I gave up on LEDs after reading so much about how the stock headlight enclosure just doesn't give them the pattern you need, and that I don't want to go HID. So this is probably the direction I'd like to go, assuming the safety for the housing/wiring.
