Shift into another gate and then try to go back into 5th. What happens then?Is it normal to not be able to shift into 5th when the car is parked and off?
Cooper is exactly right. My stepson did the same thing when he was going through the gears for me. I was watching the cables to make sure I didn't mess anything up while installing the acuity bushings. He stated the same thing from inside the cabin. the gear ratio is fairly close so it feels like you are going into 2nd when you are really going into 5th.Make sure you're actually aiming for 5th. Reverse isn't locked out when the car's off, so it could be that you're just too far to the right. My sample size isn't too big, but I've never been in a Civic that didn't let you shift into anything you want while the car's off.
