kadireren
- kadir
- Aug 16, 2020
- 14
- 102
- 50
- Turkey
- Civic 1.5T Hatchback Sport + CVT (182ps)
Hi my friend has a problem with ktuner please have look.
He has a 2020 sedan executive 1.5cvt with safety features. After insisting so much, ktuned added support for his ecu. He got error codes and they put an option to disable those errors. now with the final version he still has problems.
1 - His vehicle is completely stock and only at 7600km. He loaded the dual tune tune. When he wot his afr is ridiculosly low such as 8.5-9. İn eco mode it is a little bit higher but again under 10. I did some custom maf scaling(-%10 from 3.8v to 4.5v) but it didn't affect anything. When stock it is between 10-10.5 like other Eu versions.
2 - in normal mode when he wot for a while it gives the p0234 error code (it is an overboost error but absolutely there is not overboosting) and engine goes limp mode.
3 - I think he has a problem with fuel pressure because as you can see in the datalog his target fuel pressure is 18000kpa but my car is a sport + hatchback 1.5 cvt and I have target pressure 21000kpa.
ktuner told us to disable p2A00 error code so engine check light isn't on because of low afr
what do you think??
what do you think??
