Rear door won’t lock with keyfob or key
JarettS
Jarett
PA
2016 Civic LX
Hello
I have been having an issue with my 2016 LX where my driver rear door will almost never lock with the key fob or manually with the key. I must use the button on the inside of the driver rear door to lock it. I’ve tried new batteries and both key fobs. It will lock 1 out of 10 times randomly. All the other doors lock fine. Everything else works on the key fob.
Any help would be appreciated. Thanks!
shoegazer
Raleigh NC
2018 Civic LX Coupe 2.0 (CVT)
I can't imagine why this would be an issue. But check the child safety lock on the rear door. And see if changing its position makes any difference.
JarettS
Jarett
PA
2016 Civic LX
The child lock causes the door to not lock? I didn’t know that. I thought it was So the door can’t be “un” locked from the inside. that’s why I didn’t try that. My issue is the rear drivers side door doesn’t lock using the key manually by inserting in into the lock itself or using the keyfob. Anyway I tried changing the child lock position but it didn’t help.
shoegazer
Raleigh NC
Yeah. So far as I know it's just a interruption in the linkage from the handle. But it was something to try. Good luck.
shoegazer
Raleigh NC
The only other stuff that comes to mind is to disconnect the battery and do a global reset of everything. It sounds like your key is communicating with the car and the signal is being received. While I haven't heard of this specific issue; the answer, more and more, with our cars seems to be to reboot the system when all else fails.
JarettS
Jarett
PA
2016 Civic LX
That sounds like a good idea. how do I do a global reset? Just disconnect the battery? Or is there more. Thanks.
shoegazer
Raleigh NC
Write down your radio settings and sound preferences.
Disconnect the positive battery cable and walk away for about a half hour.
IIRC... this will reset everything to factory. And, hopefu;lly, solve your issue. If not; it's one more troubleshooting step that you have crossed off of the list.
JarettS
Jarett
PA
2016 Civic LX
I’m gonna try that. Thank you for your help.
shoegazer
Raleigh NC
Forgot to mention...
Be very careful that you don't unscrew the post terminal bolt any more than necessary to wiggle the thing off. There's a lock nut on the other side that will fall off the bolt and into the abyss of the engine bay if you go too far.
JarettS
Jarett
PA
2016 Civic LX
Thanks. Good to know. I’ll post if it fixed it or not.
JarettS
Jarett
PA
2016 Civic LX
That might have actually fixed it. All doors locked 10 out of 10 times. Thanks a lot man! Cheers
