Dave B
- Dave
- Oct 19, 2019
- 60
- 767
- 468
- Whitby On Canada
- Corvette Z06 (sold) 2020 CW
Ok, I may be barking up the wrong tree here but I have a few questions for those who use turbo blankets for track use and heat management. I do understand their benefit when driving around town or on a dyno but not so sure this is that effective on track.
1) The blanket causes more heat to end up downstream into the exhaust header and hopefully out of the engine but it must also make the turbo run hotter and will transfer more heat back to the block. This is likely a benefit on the exhaust side but a detriment on the compression side. If there is good airflow over the turbo (which is not likely in an FK8 but is improved with proper hood vents) there may be benefits of cooling the turbo somewhat. Meanwhile the oil that circulates into the turbo will get hotter with the blanket on than without. I don't know how much the oil will heat up from this alone.
2) I understand that the positioning of the air intake plumbing immediately above and behind the turbo will really influence IATs but if there is enough airflow around and through the plumbing will the turbo blanket make any difference? Would it not make more sense to use a heat reflective coating on the intake plumbing?
3) Given that the engine is making the same amount of heat with and without the turbo blanket, is there risk to the exhaust system of shifting more heat there and is there risk to the turbo itself from using a blanket? Does the heat that doesn't get out of the turbo that is under the blanket just end up increasing temps of the exhaust, and flex pipe that are still in the engine bay?
I get it for street use and drag use that a turbo blanket can be really helpful but does it actually make much difference on track where total heat management including ECT, oil temps and IATs is the biggest issue?
