Maintenance minder changed after oil change from "A 7" then "B"?
be12nard
InvisibleWorld
Bay Area, California
2014 Civic EXL
Hi everyone,
My Si used to show "A 7" in the maintenance minder. Oil has changed a week ago. After reset the maintenance minder, oil life is 100%. However, I am seeing "B" in the dashboard. Google search said " Replace engine oil* and oil filter. Inspect front and rear brakes. Check parking brake adjustment. Inspect tie rod ends, steering gear box, and boots. " Since I had already changed the oil and oil filter, how do I get rid of it? I tried to contact Honda service department, but they never picked up the phone.
Your help is greatly appreciated.
Honda Civic 10th gen Maintenance minder changed after oil change from "A 7" then "B"? ?hash=a999692a668d7d2bc9fc687fab694ebd
Sport-injected
Scott
Central Jersey
www.youtube.com
2019 Civic Si, 2006 Saab 9-3 Aero
Hi everyone,
You should be able to clear it in your infotainment vehicle section. Your owners manual can guide you to it.
SDAlexander8
Steve
Indianapolis, IN
#7 is for a brake fluid service. The dealership should not have reset that without bleeding the brake lines.
A indicates that your next oil change should be oil only.
B service is an Oil change with a new filter change on the next oil change
#1 next to A or B indicates that you should have your tires rotated with your next oil change
bikejog
ny
2020 Civic Si Coupe. 2000 Honda Prelude (donated to charity).
That screen shows the oil life and the item(s) due at the next oil change. It's in the owner's manual
Honda Civic 10th gen Maintenance minder changed after oil change from "A 7" then "B"? 1617550371530
Barticus520
Ny
2017 Honda civic sport touring
Go to settings then vehicle then maintenance info. You can see everything that is due for service and it tells you what each letter and number stands for before you reset them
