+ upvote. I have 2 white LEDs now with laminx light smoked tints. But if and when one of them goes out, I’m going to go for the switch backs. Best of both worlds!You can have both! Lasfit makes switchback LED fog lights that switch between yellow and white. I haven't done it myself yet, but there are a few review videos.
it switches between the colors when you turn on/off the lights.
https://www.lasfit.com/collections/...o&utm_medium=affiliate&variant=30123469111380
I have a couple questions. First will they switch to the other color every time you start the car again? Like if they're yellow when I turn the car off will they be white when I start it up again? Also if you flash your high beams will they change then as well?You can have both! Lasfit makes switchback LED fog lights that switch between yellow and white. I haven't done it myself yet, but there are a few review videos.
That's actually a cool idea if light output/colour is good on both colors. "Cool a.f." for normal driving, "Functional a.f." for foggy/rainy driving... lol. I like it.You can have both! Lasfit makes switchback LED fog lights that switch between yellow and white. I haven't done it myself yet, but there are a few review videos.
I have no idea since I haven't put these in yet myself and I've wondered the same things myself. It looks like @PhillyFenom has so he can perhaps answer some of these questions.I have a couple questions. First will they switch to the other color every time you start the car again? Like if they're yellow when I turn the car off will they be white when I start it up again? Also if you flash your high beams will they change then as well?
Does the color change every time you turn your car off/on? And does using the high beams affect the color switching at all?Go switchback. Best of both
no it doesnt affect anything really; its a switch that when you first turn on shows the lights white, then turn off and back on and then its yellow; repeat to turn off/back to whiteI have no idea since I haven't put these in yet myself and I've wondered the same things myself. It looks like @PhillyFenom has so he can perhaps answer some of these questions.
That's good to hear. I see that you got yours from Socal accessory. I may end up getting the same set since I am local.no it doesnt affect anything really; its a switch that when you first turn on shows the lights white, then turn off and back on and then its yellow; repeat to turn off/back to white
Not yet. Been lagging. I'll try to get a video of how it looks at night as well as how to switch between the 2 settings.That's good to hear. I see that you got yours from Socal accessory. I may end up getting the same set since I am local.
Do you have any pictures of the light output of your fog lights?
Sorry it took awhile been busy with stuff but here you goThat's good to hear. I see that you got yours from Socal accessory. I may end up getting the same set since I am local.
