just how small is the turbo?
teders
Ted Dorosheff
Mclean, Virginia
2017 Honda Civic SI
Keep hearing everyone say how small the SI's turbo is, but i have yet to learn any dimensions. Does anyone know what the dimensions of our turbo's are? Are turbos even measured in an HxLxW way or is more complex than that?
integra15
Ann Arbor
2017 Civic SI
I'm no turbo expert but it looks tiny. Search 18900-5PA-A01 on google and you can see a diagram
Doc_C
Omaha
2017 WOP Civic Si Sedan
What he said.
It's a MHI (Mitsubishi Heavy Industries) turbo. The main difference between the Si turbo and the EX-T turbo is the turbine wheel (hot side blades). The Si has the same turbine wheel as the CRV which is a 9 blade wheel. Otherwise the two are pretty similar.
Doc_C
Omaha
and as you can see, the non-Si's have an 11 blade turbine wheel lol
jpuhl777
Jp
Minnesota
2017 Civic SI Coupe (WOP)
wow, that is small, geez
I immediately had the sound from the Price is Right in my head when someone looses :)
teders
teders
Ted Dorosheff
Mclean, Virginia
2017 Honda Civic SI
What he said.
Sort of confused by your wording. You say that the SI and CRV turbos are the same, with a 9 blade turbine, and the EX-T is different, with a... how many blade turbine wheel?
Non-Si 1.5T Civic has 11 blades.
mis3
PT
Ontario
Mercedes, 2018 SI Coupe
Glad I found this. I thought the Si and Regualr Civic shared the same turbo engine.
choo
FL
'17 Hatch Sport 6MT , 1995 240sx
When I took off my downpipe and had a look into the exhaust side of the turbocharger I was slightly depressed.
lol, its what, a 40mm turbo? Pretty sad that the wastegate flapper is bigger than the turbine wheel haha
CivicChina
Xiamen, China
Civic 1.5t 6MT Cosmic Blue
it is basically the same, with some minor differences to increase power
