JDM UFO Dome Light
Kane666
Jason
Pennsylvania
2018 Civic Sport Touring
This thing is pretty neat. A few pointers...
Part numbers;
08E14-T4R-000 Sub-harness
08E13-E81-010 Light assembly kit
A ground cable comes with the main unit. The connector is too big to fit into the harness hole. I had to drill out my hole to make it fit. I hate doing things like that, modifying OEM equipment.
There is a sub harness that is for this, you still need to do the ground cable thing.
The main assembly comes with 2 screws, a plate, two washers, two threaded clips for the screws to go into, the assembly, and the cover. The sub harness comes with some foam and silver squares. I have no idea what that is for, I didn't use it.
There is a little LED map light if you don't want a whole bunch of light. There are settings called fancy, I have no idea what they are for, nothing lights up in that position.
Honda Civic 10th gen JDM UFO Dome Light 20181207_220321
Honda Civic 10th gen JDM UFO Dome Light 20181207_220603
Honda Civic 10th gen JDM UFO Dome Light 20181207_223250
Honda Civic 10th gen JDM UFO Dome Light 20181207_223303
Honda Civic 10th gen JDM UFO Dome Light 20181208_001000
Honda Civic 10th gen JDM UFO Dome Light 20181208_001017
Honda Civic 10th gen JDM UFO Dome Light 20181208_001023
Deezy
Daniel
Covington, Ga
2018 Civic LX Sedan 6MT (FC2)
Pretty cool! Wouldn't mind seeing a pic of how it looks in the daytime. The foam squares are most likely to put on the harness to keep it from rattling.
wEaK Squad
*ATL*
Justin
Atlanta
18 CBP FK8
Anyone know if there’s a way to have the blue lights turn off with the car?
Kane666
Jason
Pennsylvania
each switch is 3 position. on, fancy, door. one switch controls the blue one controls the actual light. there is also a smaller light as shown in the last pic activated by the push button in the middle. im still trying to figure out what fancy does. they packed a lot of options into this little thing.
Dis4Damion
Damion
MA, USA
2019 Honda CR-V Touring AWD
Is this available with a red ambient light? (to match Si/Type R/Sport)
Riko
Erik
Belgium, Ghent
Civic 1.0L Turbo, CVT, Elegance trim
arent the 3 functions of each button just the same as the 3 function of the button on the stock dome light?
Stock has: on (all the time) - middle (on when door opens) - off (all the time)
On this fancy dome light the "off" and "middle" seemed to be turned around, but in total you have the same functions? on = on all the time like stock - "door" = "middle" and shines when doors are opened? - "fancy/room" = "off" on the stock dome?
Might order this too cause I like the look and functions and the install video was very clear! :)
Kane666
Jason
Pennsylvania
i never got the blue led to turn off with doors.
Kane666
Jason
Pennsylvania
seems so. i havent messed with this in awhile
98-0425
Nick
Las Vegas
18 Civic Type-R #12307, 98 Integra Type-R #0425, 07 Pilot EX-L, 17 Pilot Elite
Modified the JDM Honda Access dome light by desoldering the blue LED and soldering in red LED.
Pictures:
1. Package
2. Fancy light, now in red
3. Spot light
4. Dome light
