MeisterR
- #16
Ride height is a bit more complicated.@MeisterR Thanks for the in-depth reply! Sounds intriguing. So is adjusting the softness of the ride and the ride hight something that an average consumer could do on their own? - i.e. doesn't require special tools or expertise and doesn't require us to take anything apart?
That should be set at the initial installation, and the car alignment should be set after.
Once ride height is set, you wouldn't be able to easily adjust it.
It will require the wheel to come off to adjust the suspension, then alignment set again as the value would change after the adjustment.
The main thing is you "CAN" set it to where you want it the first time.
And if you are mechanical minded, you can just change the ride height with the tools provided and a jack.
I lower the ride height on my S2000 when I was testing the prototype ZetaCRD coilovers in my garage using nothing by the spares tool kit from the car.
So it is do-able, and I am not very mechanical minded (I am the geek that sit behind computer screen and look at lots of pretty graph).
Damping adjustments on the other hand is dead easy.
It is just twisting a knob, clock wise to stiffen, counter clock wise to soften, and there is little clicks in the adjuster so you can make sure the left and the right side is the same.
The long as you can get to the knob at the the top of the damper, which is very easy on the front of the CivicX, and I haven't had a chance to see the rear.
I have attached a picture of what the damping adjustments looks like, it is the little red knob in the centre of the top mount.
This is for an FN2 Civic and i got a feeling the CivicX coilovers will look pretty similar to this.
Jerrick
