Yeah, I produce 30 tons of argon every day at the air separation plant I run. I've got more than enough!Argon is a the gas they put in between the panes of insulated windows, if you ever need some.
I thought it was obvious, but then again this is the internet and far dumber things have happened. I appreciate the concern.
As for what I actually think of nitrogen inflation: you would be better off buying a more accurate tire gauge than spending a dime on nitrogen inflation
1. Nitrogen still follows the ideal gas law, it will drop pressure in colder temps similarly to air
2. Over the course of time it will lose less pressure, but it will still lose pressure. This will still require monitoring and inflation. I don't know about you, but inflating it 3 psi vs 2 psi doesn't matter to me.
3. I don't have a nitrogen compressor at home, inflating would require extra work to drive to a shop with the tank
4. The accuracy of inflation pressure (because of crappy gauges) likely varies more than the pressure loss benefit of nitrogen. Accuracy still an issue for air too!
5. corrosion benefits are overplayed vs what the average consumer will ever see.
6. There are benefits, but the passenger car market is more of a marketing exercise than truly a consumer benefit.
I went and had Costco put in Nitrogen on my X. I live at altitude, days with high humidity and days where temps can change as much as 50 degrees. I hate adding air when its winter and 20 degrees out. #nitrogenforthewinTERThere has been a few studies on this one by the NHTSA in America and one by a professor daws. Both run multiple tests at there are a couple rules to weither or not it is worth it.
1 its measured by the area of the tire (is it big or small) the larger the area the more nitrogen has an advantage).
2 it matters on the humidity of the air, air with high humidity fluctuates in temperature greater, and psi changes more. In a high humidity area the advantages of nitrogen are stronger
3 it depends on the activity of the vehicle, driving around in the city at 25 mph its not all that effective, driving on the freeway all the time its worth it, racing on a track is a must
Links to both NHTSA pdf and prof daws study on this page
Please read the pdfs for yourself and dont let people tell you wrong information
http://bvmotorsports.com/home/learn/wheels-2/nitrogen-filled-tires/
Haha that's what my dealer told me today he said they don't even have nitrogenHope it was a really great deal. The air we breath is 78% nitrogen (21% oxygen and the rest basically water).
Statistics say it'll make your car fly up to the sky like a balloon....Costco now offers a free fill of helium with a purchase of four new tires. Advantages are much better gas mileage because the tires are lighter. It will also improve handling as the car will be easier to steer. How much you wanna bet MOST people will believe this.
If you get flat tires, you can say, "Look! The air in my tires argon!"After nitrogen and oxygen, the next largest component of air is argon.
Ba dam tss! heheheIf you get flat tires, you can say, "Look! The air in my tires argon!"
I'm with ya hahaStatistics say it'll make your car fly up to the sky like a balloon....
Where do I sign?
