Hell167
- Eric
- Mar 27, 2021
- 9
- 46
- 13
- vancouver
- Fk8
For those of you who installed a remote start on your ctr know you need to temporarily disconnect the yellow or red wire on the cpss. This will give you a whole bunch of errors.
Since the red wire goes from 4.5v to .5v when clutched is pressed and the yellow wire goes from .5v to 4.5v when clutch is pressed. It is just a matter of flipping the wires while cranking. This can be achieved with 2 relays.
Most people have issues accessing the cpss wire from the connector. I have found this connector both female and male 7283-2763-30 and 7282-2763-30.
The connector for the ctr cpss connector can be purchased here.
https://a.aliexpress.com/_mMjpM7e
Now it's pretty much plug and play.
With the fortin evo one the dark blue wire will output ground until 1 second after car start. Here is the way I wired it.
Relay 1 and 2 pin 85 goes to 12v
Relay 1 and 2 pin 86 goes the evo one dark blue wire
Relay 1 pin 30 goes to red wire sensor side
Relay 2 pin 30 goes to yellow wire sensor side
Replay 1 pin 87a and replay 2 pin 87 goes to red wire harness side
Relay 2 pin 87a and Relay 1 pin 87 goes to yellow wire harness side
Not pretty but it works
