Cooling fan.
Xaymaca
Jermaine
South Florida
'08 Mazda Mazdaspeed 3
Quick question I notice that at idle my temperatures go up. I pulled over at a gas station and noticed the cooling fan doesn't come on, unless I have the AC on. I am trying to figure out what is going on. I just noticed this start happening when I installed my rev9 intercooler. Prior to this I don't recall this happening. Is anybody else having this problem?
This is normal behavior for that ECU and has nothing to do with the intercooler. :thumbsup:
Xaymaca
Jermaine
South Florida
Ok because when I am idling it will go up to 206 degrees and before this never used to happen to my knowledge.
Not abnormal. No worries. Turn on your AC if you want it to go down. :)
CVTKiller
JT
Miami
2019 Civic EX-T CVT
Question, When I do Pulls I turn my AC off, But im having the same Issue as this guy with my fan only on when AC is running and it gets High temps will i run into any issues. and Im assuming there is no fix for this?
CVTKiller
JT
Miami
2019 Civic EX-T CVT
It runs hot at idel, not when i do pulls bit temps due fluctuate a lot on normal driving.
Beholder84
Eric
Santaquin, UT
2019 Honda Civic Si Coupe
This seems normal, but if you're that concerned there's a fan control section within KTuner where you can adjust how the fan works. I left my parameters alone, but this is what it looks like.
Honda Civic 10th gen Cooling fan. KTuner_FanControl
