Best Coilover options
JonasJoker
Jona
2018 Civic SI
I’m the market looking for some good quality coilovers, I want you guys to help me find the right option for my SI sedan...
I don’t know much about coilovers but I want to know if the ones I will buy, works the best on my car knowing all functions that the car has like
sport mode, damper, camber, spring rate, rubber upper mounts, weights...
The one I know rn has a good quality is Tein because it’s made for the exact SI functions
Also know that brands like KW, BC racing are good...
I’d appreciate if you guys help me find the right set up... thank you
Honda Civic 10th gen Best Coilover options BC7E6318-FEEE-44FE-AFC6-8174685AA980
si_well
Anthony
NE Pennsylvania
2020 Civic Si
Most reputable brands offer nearly identical quality coilovers. All three brands you mentioned are solid choices, but I personally like BC racing.
And for the record, there currently isn't an aftermarket complete coilover set offered that allows you to utilize the factory adaptive dampening system. Any coilover set you get will have to paired with a sensor delete/dummy module that plugs into the ADS sensor to trick it into thinking it's working so that you aren't throwing codes.
YankeeSi
jerad
SOCAL
2018 si sedan
JonasJoker
JonasJoker
Jona
2018 Civic SI
Seth_FC3
Seth
Miami
2020 SI coupe
All the brands you've noted are good. As long as you get a good reputable brand with the ADS block would work great. Keep in mind it's also based on how low you go, spring rates, dampening, etc.
YankeeSi
jerad
SOCAL
2018 si sedan
But these ones doesn’t come with the bypass right?
You pay extra for those, it's really not hard to hit a button on startup. So to me it's a waste of money for the bypass modules.
Seth_FC3
Seth
Miami
2020 SI coupe
I mean, maybe for you. I use my car in sport about 95% of the time cuz I make full boost in sport. I know the ADS light constantly on it would bother the hell outta me
YankeeSi
jerad
SOCAL
2018 si sedan
I use my car in sport 100% of the time, you literally hit a button on the steering wheel and then all you see is the tiny info warning light. Tein's come with ads bypass modules... are 16 way adjustable which is trash compared to the others and the spring rates are too low. Pay for better coilovers without them and save the bypass module money for go fast things.
YankeeSi
jerad
SOCAL
2018 si sedan
I use my car in sport 100% of the time, you literally hit a button on the steering wheel and then all you see is the tiny info warning light. Tein's come with ads bypass modules... are 16 way adjustable which is trash compared to the others and the spring rates are too low. Pay for better coilovers without them and save the bypass module money for go fast things. Everything else in sport mode still works so you're paying hundreds of dollars to get rid of a tiny light lol.
Seth_FC3
Seth
Miami
2020 SI coupe
I use my car in sport 100% of the time, you literally hit a button on the steering wheel and then all you see is the tiny info warning light. Tein's come with ads bypass modules... are 16 way adjustable which is trash compared to the others and the spring rates are too low. Pay more for better coilovers and save the bypass module money for go fast things.
Yea but the "i" is always on. Personally I wouldn't mind spending the money. If you're already spending the money you might as well do it correctly the first time around. But that's just me
YankeeSi
jerad
SOCAL
2018 si sedan
Correctly ? My suspension is leaps and bounds better than stock so it's already been done correctly i just don't worry about a meaningless light, you do you boo.
Toppo | Si
Duane
2020 Honda Civic Si Coupe
Driving without that ADS bypass, have you run to any problems?
I do think that spending $320 just to get rid of lights is ridiculous..
madchiller
Chad
DFW, TX
2018 Civic Si
I went with the HKS HiperMax IV coils when they first came out with the optional ADS bypass. I bought them from a member on here after he sold his Si for a Type-R while waiting for them to ship from Japan.
While I LOVE the way they ride and the adjustments being fairly easy the one big thing I do not like is the fact they don't come with front camber plates.
http://stores.axionind.com/honda-civic-si-fc1-fc3-2017-hks-hipermax-iv-gt-coilovers/
Dawsfc3
Dee
Norcal
2018 civic si
No problems just have to keep pushing the menu button to get rid of the warning message. HeelToe has cancelers on sale for around $225
GBD
Graham
Northern KY
2019 Civic Si Coupe
Late to this thread, but does anyone have any experience or thoughts on these cancellers and how they're mounted? Any concerns with water/corrosion with them mounted outside like below:
Honda Civic 10th gen Best Coilover options 1601246503454
