Performance options
17SIvic
Ryan
Des Moines Iowa
2017 Honda Civic SI
Hello all, just recently bought a 2017 civic SI and I want to know what I can do to get some HP gains. I looked around and most people are saying tune, tune, tune. I’ve never owned a civic before so this motors new to me. Any and all help is welcomed. Thanks!
Hate to be another one of those guys.
But...
A tune is the best power mod. By far.
You can do basics like intakes and exhaust and most of your money will go into sound, not real performance gains. Plus, a tune will give you more than just extra power. It will give you better everyday driveability too.
Here's a good basic plan for a better Si:
#1 Ktuner or Flashpro
#2 Better tires
#3 CTR rear sway
#4 Acuity shifter mods
Thank me later.
kimtyson
Kim
York, Pa
2020 Blue Civic Si Coupe
What he said ^^^^. The Si is already a decent machine from the factory. It's just somewhat crippled by some decisions in tuning so get your tuner of choice as a start for the most performance of this beauty.
17SIvic
17SIvic
Ryan
Des Moines Iowa
2017 Honda Civic SI
But...
#2 Better tires
#3 CTR rear sway
Thank me later.
Awesome, thank you! I heard from a couple people that flash tuners are not the way to go as well cause they can only do some much is that true?
86salmon
It's Hedley, Hedley Lamarr!
Chucktown, SC
An ECU flash tuner such as ktuner or flashpro give more options and flexibility in tuning than a piggy back. The ultimate is something few can afford, motec
The downside to any tuner is, if you're worried about warranty, it's gone. Just do wheels, tires, suspension, and shifter mods if you have any engine warranty anxiety.
17SIvic
17SIvic
Ryan
Des Moines Iowa
2017 Honda Civic SI
I’m not worried about warranty, I’m more worried about spending $600 on a tuner that only gave me 50hp lol. I guess what I’m aiming at is tryna have it pushing 300, but idk if that’s possible with a flash. What’s your opinions?
Drake
Honda Civic Si
Adding 50 hp is a 25% increase in power for this civic, which is no small amount. If you're looking to reach 300hp I'm guessing you'll probably need a turbo upgrade, which will cost you a lot more than $600. However, keep in mind the Si is more about handling prowess than big power. Going fast in a straight line for cheap is what muscle cars are for.
86salmon
Chucktown, SC
You'll need more than a tune to get those numbers. FBO with turbo swap gets really close on 93 octane. FBO with turbo swap and flex fuel pushes you over
. Regardless, you'll still need a tuner to get there. Might as well start with it if that's the direction you want to take your car.
As was stated above though, this isn't really a build up, and go fast in a straight line platform
Annexed
Austen
Wisconsin
2017 Civic Si
182whp / 206tq - Factory Calibration
208whp / 258tq - Ktuner Starter 23psi
237whp / 281tq - TSP Stage 1 Tune
245whp / 278tq - Ktuner Starter 23psi w/ Flex Fuel
270whp / 327tq - TSP Stage 2 Tune w/ Flex Fuel
People usually go with the TSP stage 1 tune. If you do go with that, make sure to buy your ktuner from their website and you get the tune for free
Honestly, the Si isn't the vehicle to push 300+ hp without beefing up the internals.
The 237whp / 281tq TSP Stage 1 tune may not sound like huge numbers, but remember, this is a 2900 lb. car. Combine that power with some small suspension improvements and you have a helluva well rounded ride.
vieux georges
georges
Saint Jerome ,Quebec, Canada
2017civic si coupe
You mustn't dream.
Increasing the power to 300 hp costs a lot more
than 600 $.
In addition to modifications to the engine itself,
you'll need a clutch that can handle the power
and torque.
You'll also need to change the R.M.M. as well as
better tires and rims to transfer the power to
the ground......
That is the bare minimum.
If you do the total, you're looking at several
thousands bucks.
Good luck with your mods.
jakdotdot
Cali
2018 SI
No, you aren't getting 300WHP out of this car with a tune. Your not getting 300whp without throwing thousands dollars at your car (Bigger turbo, upgraded clutch, and supporting mods).
BTW, 50WHP for 600 bucks is cheap as far as HP is concerned.
amirza786
A
Northern California
But...
#2 Better tires
#3 CTR rear sway
Thank me later.
Yep. Best boom for your buck. It's a safe way to gain an additional 55 whp and you can remove it yourself if needed. I would personally recommend buying a Ktuner from Two Step Performance bundled with their TSP Stage 1 tune. With the mentioned mods in his list. What better way to spend your stimulus money?
shibles
Seth
Athens, GA
2018 Honda Civic Si Coupe
Best recommendations: stage 1 tune, springs or other for suspension rigidity, short throw shifter, and tires and you'll have a fun machine. If you're gonna be pushing hard a lot, look for better cooling options, cooling is a common issue with track driving (aka intercooler, oil cooler, etc).
This point is contested a lot but imo flex fuel isn't a good option if you want to keep longevity. Don't let potential +90 hp for like $300 fool you, injectors don't handle it well (and there is a large lack of aftermarket fuel delivery systems for anything but Type R) and clutch will definitely start to slip.
If you're looking for more: wheels, rear motor mount, Type R clutch and flywheel retrofit, turbo swap, CAI, performance exhaust, cat delete, etc are all common performance mods on this platform.
Happy modding!
Crakzor
Mathanael
DFW
2014 Chevy Cruze, 2020 Civic Si
will techs see it was flashed twice?
