@Thawk
I’ve been looking for this! I’m getting a set of Sparco Corsa and I want the OEM Honda center cap and two sets of your rings.
Can you tell me what size OEM cap I need to get (just want to make sure I get the right size for your ring)
Thanks!
The factory ones for the CTR fit just perfect. To say "size" if you're looking for non-OEM caps is a bit complicated because the diameter of the tabs needed to grab the wheel is different than the diameter of the circle/logo itself.
That said, I designed my rings to work with the OEM 69mm center caps - hope that helps.
Shoot me a pm if you want a set or two of rings - happy to help.
Thanks to @Thawk for the adapters. My low-rent winter setup looks way better now with the Honda center caps. I had a couple pop out last year and ran with no caps for the rest of the winter, but these adapters are exactly what I needed. He shipped fast and the fit is perfect.
