2019 Honda Civic won’t start.
Willybman7
Will
Louisiana
‘19 Civic Sport
I went to use remote start this morning walking up to car and heard it try to crank then nothing. Waited few minutes later to try and start it with push button and everything inside and headlights came on but not the engine. Tried jumping it few times and nothing. Brought to autozone to have tested and everything came back fine. Could this be the starter going out?
latole
Vaudreuil,Quebec ,Canada
"....and heard it try to crank "
If engine (want to) turn with starter, starter is good
latole
Car may need a new battery. often read on this forum
Hot temperature ( Arizona is very hot) is very bad for car battery
BrandonSmith
The Greatest Country on Earth
2016 Civic EX 2.0L
If the car cranks, it is not a battery nor a starter. How could the car crank if the battery was bad? How could the car crank if the starter was bad?
What does a car need to start? Air, fuel, and ignition.
Is fuel getting to the cylinders? Is the fuel pump working? Is the fuel pump fuse blown?
Check all the fuses under the dash and under the hood - there are several fuses that could lead to this issue.
