Question on that. How level does the car need to be to get an accurate "measurement"? Say I just lift the front of the car, like most diy-ers would do. Will the angle of the car affect the check drain?Lift the car, there is a check bolt above the drain bolt. There is no actual way to check the level, only if it’s full. If it’s full fluid will drip out slowly from the check bolt.
thanksLift the car, there is a check bolt above the drain bolt. There is no actual way to check the level, only if it’s full. If it’s full fluid will drip out slowly from the check bolt.
