Video of feet while shifting
  1. hashsi99
    hashsi99 Member
    Mar 20, 2018
    48
    26
    Chicago
    2018 Civic Si Coupe
    does anyone have a video of their feet while upshifting thru the gears on their Si? The clutch engagement seems to be really high. I feel as if I’m letting the clutch out too slowly (not riding it, but definitely not popping it out quick).
    Shifts are smooth. But I’m sure I can release the clutch quicker.
    Thanks
  2. tehSteve
    tehSteve GrayBeard McGootch
    Sep 3, 2017
    587
    365
    Occupation:
    #SiClubNJ Chapter
    New Jersey
    Steve
    2011 BMW 335xi, 2017 Si Coupe, 2010 EvoX GSR, 2005 BMW z4 3.0i
    You won't be able to release the clutch quicker because of the built in rev-hang (tunable) and the clutch delay valve (can be removed).
    It's not you, it's Honda.
    Clutch engagement is high from factory and if you remove the CDV it will probably feel even higher than what you are used to because there is no more "slip assistance", so it pretty much just grabs and goes :D
    Design and hashsi99 thanked this.
  3. OP
    hashsi99
    hashsi99 Member
    Mar 20, 2018
    48
    26
    Chicago
    2018 Civic Si Coupe
    will the slower release burn out clutch quicker??
  4. tehSteve
    Sep 3, 2017
    587
    365
    Occupation:
    #SiClubNJ Chapter
    New Jersey
    Steve
    Yeah. A slower releases makes you stay in the friction zone area longer.
    However, 3-4-5-6 you don't need release as slowly. Just don't pop the clutch or you get a buck.
    1-2-3 basically makes you slowly release and the higher you rev, the worse it is on your clutch.
    From 1-2-3, I shift at 3krpm and try to get out of this gear as quickly as possible.
  5. RunningHot2017
    RunningHot2017 20 years. Smashing gears.
    Jan 4, 2018
    181
    112
    Alabama
    Jared
    2017 Honda Civic Si
    Yeah the trick is rev matching. The rev hang is heinous on these Sis (planning on tuning next month) but the best way to help with this is shifting much sooner, if you shift in the 2k-2500rpm range the bite wont be as bad you can accelerate quite quickly shifting briskly and soon. If you get up to 4k rpms in 1st or 2nd gear, Count to 2 or 3 seconds and then smoothly release the clutch.
  6. OP
    hashsi99
    hashsi99 Member
    Mar 20, 2018
    48
    26
    Chicago
    2018 Civic Si Coupe
    Are you giving gas at the same time after holding clutch in so long?
  7. RunningHot2017
    Jan 4, 2018
    181
    112
    Alabama
    Jared
    2017 Honda Civic Si
    If I get my rpms up, I dont give any gas. I dont have too, It shifts like butter. But if im taking off kinda quick I will release slowly and give a little gas right before the bite to help speed up the wheels and match revs. I dont stay in that friction area very long, once I give gas, I let out on the clutch pretty quick. It just takes lots of practice. When I got the car my shifts were always erratic, but now I can shift like the car it is an automatic. My girl really appreciates the finesse
  8. Dimitron84
    Dimitron84 Senior Member
    Mar 25, 2018
    399
    172
    Youngstown, OH
    Patrick
    2018 Civic SI
    My issue is still going from first to second, not sure if there is just too much rev hang even if I try to release slow I always get a little judder, every other gear is smooth including releasing on first. Anyone else have this issue or have had this issue? I've had car for only about a week so far.
  9. BoostedSiCoupe
    BoostedSiCoupe Senior Member
    Mar 25, 2018
    1,197
    1,032
    Occupation:
    Driving my Si
    Cesspool
    2019 Civic Si
    1st to 2nd is a bitch in this car. My 1 - 2 shift is rarely ever smooth.
    10Gensi, Ginst89 and Tim818 thanked this.
  10. Dimitron84
    Mar 25, 2018
    399
    172
    Youngstown, OH
    Patrick
    2018 Civic SI
    Thank God, I thought I was doing something wrong, I went to extreme of shifting at 8mph to 2nd and that sorta makes it smooth but no fast acceleration that way.
    10Gensi thanked this.
  11. BoostedSiCoupe
    Mar 25, 2018
    1,197
    1,032
    Occupation:
    Driving my Si
    Cesspool
    2019 Civic Si
    Yes i have to shift slow 1 to 2. The issue is the engagement point is a little too high, and the engagement itself is very vague feeling. All my upshifts to the other gears arent as bad, though.
  12. DoubleDown
    DoubleDown Senior Member
    Jul 29, 2017
    115
    2017 Civic Sport Hatch 6MT
    Can you guys heel/toe in your SI's? For the Sport, the brake pedal protrudes further out compared to the gas pedal, thus making heel/toe very difficult.
  13. RunningHot2017
    Jan 4, 2018
    181
    112
    Alabama
    Jared
    2017 Honda Civic Si
    The big shift is definitely 1-2. Its rough because of the rev hang, if you get going over 15mph in 1st you have to wait about 3 seconds for the revs to return to a calm shifting state, if you dont, you most always will bark the tires.
    ActiveArch thanked this.
  14. RunningHot2017
    Jan 4, 2018
    181
    112
    Alabama
    Jared
    2017 Honda Civic Si
    The brake and clutch do come out farther than the gas pedal which makes it a little difficult. I have rather large feet so the heel/toe isnt so bad for me personally.
  15. BoostedSiCoupe
    Mar 25, 2018
    1,197
    1,032
    Occupation:
    Driving my Si
    Cesspool
    2019 Civic Si
    I can but just barely. Its very difficult to do in this car because of the reason you mentioned. Also the center console near the gas pedal is too close, and gets in the way.
