Turning off headlights/battery issue
  1. zroger73
    zroger73 Senior Member
    Apr 15, 2017
    2,329
    4,322
    United States
    2019 Ridgeline RTL-E, 2019 MX-5 Miata GT-S
    (1) As long as the parking brake is set before the ignition is turned on, the DRLs will not illuminate.
    (2) The DRLs don't illuminate in accessory mode, which is the mode you should be in if you only want the radio on by itself. (One push of the start button without your foot on the brake on models with pushbutton start or ACCESSORY position I on models with a key.)
    (3) The Ridgeline's Truck Bed Audio will play for up to 11 hours, though its battery is a bit larger (48/620 amp vs 51R/500 amp).
  2. shihabp79
    shihabp79 Senior Member
    Oct 14, 2017
    885
    466
    Dallas
    '17 Civic Type R #2740
    Lmao, if you guys are going to tax your battery like this, go replace the factory with a deep cycle one like an Optima Red Top or at least swap it with another one with more cold cranking amps. Problem solved.
  3. turbo lover
    turbo lover Senior Member
    Apr 7, 2016
    546
    275
    Civic Hatchback Sport Touring
    Probably better to look for one with more amp-hours. Cold cranking amps is a measure of how much power the battery can provide for a short burst. Amp-hours is a measure of the battery's overall energy capacity over a longer drain period.
    zroger73 thanked this.
  4. xcivicx
    xcivicx Senior Member
    Jan 14, 2016
    744
    341
    Occupation:
    XdumdassX
    whycanogaparkofcourse.
    19 SI coupe in black former '17 hatch w/mt
    drive in movie? havent seen one of those in 25 years, at least not one that was open.
    always wondered how long this puny battery could go just listening to the radio. guess not long at all.
  5. zroger73
    Apr 15, 2017
    2,329
    4,322
    United States
    There's at least one that's alive and well since 1979 right down the road from me in Tyler, Texas. You'll have to leave the kids with the baby sitter, though! ;)
    http://lucidinc.com/apache-drive-in/
    grumpyguy6 thanked this.
  6. shihabp79
    Oct 14, 2017
    885
    466
    Dallas
    They're having issues starting the car after draining off a significant amount of charge on running electronics while the engine is off. Cold cranking amps fixes that. Anyways, I said they should get a deep cycle battery like an Optima Red Top, which are higher amp-hours batteries.
  7. grumpyguy6
    grumpyguy6 Senior Member
    Jun 16, 2017
    415
    425
    Occupation:
    IT
    PA
    2017 Civic Si sedan, 2018 Jeep Grand Cherokee Trailhawk
    Wow...the fact that something like that even existed (and bafflingly continues to exist) is awkward on so many levels
    SnapdragonTX and zroger73 thanked this.
  8. SnapdragonTX
    SnapdragonTX Member
    Jan 5, 2016
    Texas
    Turbo'd EX-L
    So after 2 years of ownership, and 50k miles on the clock (Houston...) the battery failed the test and was replaced on my recent visit for service. Of course, it is out of warranty and something that Hondacare does not cover. $117 to replace. I pressed my service advisor about the premature wear, he just looked dazed and indifferent to the situation. This new battery comes with a prorated warranty. Maybe Honda intentionally placed weaker factory batteries to the screw some owners over...but now I'm just brewing up conspiracy theories.
    @rickkonk , that is always a terrible answer from a dealership. Like electricity (or in our case battery drain lol), the dealers look for the path of least resistance to spout out an answer.
  9. brian72
    brian72 Member
    Sep 27, 2018
    44130
    Brian
    2018 Honda Civic Touring
    So I hope you guys are still checking this thread!
    In March, I bought a new 2018 Honda Civic Touring. In July, my daughter sat in the car to charge her phone in accessory mode - the first button push where climate controls are not on, etc., and visually just the radio. Doors closed, lights off, windows open on a 70 degree day. 45 minutes later, car wouldn't start. I called Honda Corp. and they said it's not normal, it's under warranty and take it in. Dealership says this is normal, all the bells & whistles drain the battery. While the dealership had it and found a bad VSA (vehicle stability) module, they gave me a 2018 Accord rental. I accidentally left the interior lights on overnight, and that started fine in the morning.
    So I get that all the bells & whistles drain the battery. Is it a matter of a better battery? Wouldn't or shouldn't Honda have put in a better, more reliable battery for it? While it's under warranty, how can I persuade the dealer to replace the battery? I don't want to threaten them, but I am frustrated with them trying to "normalize" malfunctions. (I've called 4 other dealerships, one said the same thing as my dealership about not using accessory mode for more than 5 minutes, one said comparable but closer to an hour, and the other two never heard of such a problem and didn't think it's normal.)
    In the end, what have y'all done that's "fixed" this? I, too, occasionally go with my kids to one of the last remaining drive-ins, or play the radio while I wash the car, and this battery issue is not ok.
    Also, anyone have a newer Civic? Any other odd experiences to share? One thing that's been like chalk on a chalkboard is the ACC - it clicks on & off every time it accelerates or brakes, and that clicking sound is noticeable and really frustrating, and I don't recall that during the test drive! (Another "normal" thing per the dealership, something I don't hear in this Accord rental.)
  10. MEESE15T
    MEESE15T Senior Member
    May 14, 2018
    59
    Occupation:
    Parts Dept. Manager Betten Honda
    muskegon,michigan
    Bret
    2018 Civic HB Sport
    My hometown,Muskegon Mi., has the Getty 4 drive in,its still open family friendly
