Stock clutch started slipping with ktuner 23 psi map, which clutch to buy?
BoostedSiCoupe
Cesspool
2019 Civic Si
  • Banned
  • #1
It was running good for a few days, but today on the highway, downshifted into 4th at 70 and it started slipping. It happened multiple times. Got home, flashed back to 21.5 psi, and it stopped slipping.
Sucks how weak these clutches are. And it doesn't appear we have many options yet. Which clutch do you guys recommend, and would the dealership install it for me if it took it to them? Thanks.
burningoilagain
Alberto
New York City
2018 Civic Si Sedan
Dealership would install it, but they gonna charge way to much. Find someone locally! Off the top o my head you have clutch masters, Spec.. Also id save a little more and do the flywheel at the same time.
Two Step Performance
twostepperformance.com
What are your long term power goals? You have lots of clutch options, all dependent on how much torque you want to hold.
BoostedSiCoupe
BoostedSiCoupe
Cesspool
2019 Civic Si
  • Banned
  • #4
the 23 psi basemap tune is probably is high as id want to keep it... for a while anyways
Justinus
Nowhere.
None.
If and when I start having an issue, whether stock or tuned, I'm seriously considering getting the retrofitted type R clutch from eman. Fortunately I am not tuned yet and I am not having a problem.
NoKz
Speed Limit Tester
'18 Si Coupe (Sold 12/2021)
I'll be going with the Spec Inc. SMF Stage 3 clutch and Alum FW. Current clutch is starting to slip in 4th around 4500rpm. :(
BoostedSiCoupe
BoostedSiCoupe
Cesspool
2019 Civic Si
  • Banned
  • #8
I'll be going with the Spec In SMF Stage 3 clutch and FW. Current clutch is starting to slip in 4th around 4500rpm. :(
thats what mine was doing. what tune are you running?
NoKz
Speed Limit Tester
TSP Stage 1 w/Cobra CAI. I'll be going Flex Fuel + PRL FP & DP. So I'll definitely need to replace the clutch.
BoostedSiCoupe
BoostedSiCoupe
Cesspool
2019 Civic Si
how long were you driving on it before it started slipping? i was only a few days into the 19/23 and it started slipping like yours same gear and rpm
Thanks_Enjoi
Pennsylvania
18' SI Sedan
Surprisingly my clutch lasted about 4k on a vit/tsp tune, catless dp/fp, and PRL cobra intake. I am still on the stock clutch. I just don't push it hard from 3rd on. I've been waiting for the spec 3+ with steel flywheel and now that it's out I'm hoping for a deal this weekend, as I have a crap ton of parts waiting to be put on. My girls SI doesn't slip. She has the MAP intake and a tune.
