Prl flex fuel kit with mishimoto catch can
Kingamer
Brett
Irvine, ca
19 ctr championship white, Aegean blue 18 civic ex sedan
I have a mishimoto catch can installed and I just ordered the prl flex fuel kit. What I am wondering is has anyone installed both together successfully or have any tips on how to make both work.
I could swear I have seen someone installed it but I cant seem to find the pictures so as to inspect it closely to make it work.
Any help would be appreciated
IronFusion
Fred
Philadelphia, PA
2017 Civic Coupe EX-L
Same question. Didn't see your post. Here's mine; unfortunately, it's gotten no response either.
https://www.civicx.com/threads/catch-can-on-1-5l-which-one.46250/
Did you figure something out? I've caught enough over the life of my car that I can't imagine going without a can. I'm also not wed to the can I have if a suitable alternative doesn't compete with the flex fuel kit for mounting.
Kingamer
Kingamer
Brett
Irvine, ca
After installing the flex fuel kit it is definitely gonna require a custom bracket that will push it out or it will have to be repositioned to the driver side with a new bracket and make new hoses
Kingamer
Kingamer
Brett
Irvine, ca
If you had a link itd be appreciated but the only one I've seen successfully mounted together is with the siri moto flex fuel kit. Not with the prl kit
IronFusion
Fred
Philadelphia, PA
Anyone good at fabbing metal parts?
I'd pay to keep my existing can and use the flex fuel kit I just received.
It's like there are no other cans specific for this car... So anyone with a can has the same one? Where would someone mount one of the universal cans?
Purple Drink
Ronald
2018 Civic Type R, 2007 Subaru STI, 1965 El Camino
I just bent my bracket by hand and moved it to the left. Originally I used the plastic nut holding the heat shield to the firewall. Later I snapped off the treaded part and drilled it out. Then I drill a second hole and inserted two treaded rivet nuts.
This is what mine looks like....
Honda Civic 10th gen Prl flex fuel kit with mishimoto catch can IMG_3028
Kingamer
Kingamer
Brett
Irvine, ca
That's the picture I remember seeing thanks for responding and explaining what you did
IronFusion
Fred
Philadelphia, PA
Thank you kindly!
Beta9222
https://www.instagram.com/rays_fk7/
Raymond
Maryland
If you guys don't wanna go through the hassle of altering your bracket and doing custom stuff, zipties do just as good.
Honda Civic 10th gen Prl flex fuel kit with mishimoto catch can 20200229_011403
Purple Drink
Ronald
I used the plastic clip because those aren't really threads that a bolt will go onto. Thats also the reason I later snapped it off and drilled it out for a rivet nut.
Sinistah89
Richie
Atlanta
2018 Honda Civic Type R
Mines look like this
Honda Civic 10th gen Prl flex fuel kit with mishimoto catch can 20210526_175137
FK8_K20c1
Jonathan
Indiana
FK8 Type R
Honda Civic 10th gen Prl flex fuel kit with mishimoto catch can 36F10D80-7467-4822-884B-C8F6042F1FB9
Flex Fuel V2 here. Moved the bracket to align with the stud and threaded a bolt on the other side with and impact tool.
simon_lefisch
2020 Civic Si Coupe
Were the hoses for the catch can long enough?
