FaintReality
I just picked up a 2017 Civic EX this past weekend as a commuter car and am looking to get started on my install. With this in mind, I have been reading through this section the last few days and have some DSP related questions.
- Have we still not figured out a way to turn off the preset EQ and make it stick once car is restarted? I ran by local dealer yesterday to so if they could flash it to default to off upon startup, but it was a no go.
- I can work with internal EQ since my DSP has full control of both inputs & outputs, so I plan to tap into the front pair as the rear are heavily EQ'd vs the front based on my testing. With this in mind, does anyone know if the frequency response is linear with the volume or does the internal EQ change the curve based on volume adjustments? I could not find much info on the EX as most of you guys discuss the touring model with external amp.
The two above questions are about it. I may try to get out there with the mic today and take some measurements to see if the EQ is volume dependant, requiring me to use my DSP's master volume which I'm hoping is not the car.
Thanks in advance,
Dave
Thanks in advance,
Dave
