Got Screwed on a Set of Michelin Pilot A/S 3+. What should I get now?
  1. davemarco
    davemarco Senior Member
    Jun 3, 2017
    2,136
    1,209
    New York
    2019 Civic Type R (CBP), 2001 Honda Prelude (Premium White Pearl)
    #1 davemarco, Oct 18, 2019
    I bought a set of Michelin pilot AS 3+ for my type R that I picked up new in February. I only have around $1,000 miles on the tires, but apparently they're already heavily chopped.I drive the car relatively normally, with the occasional higher speed off ramp. I had my alignment checked and it's almost perfect, which is to be expected from a brand new car. Yet despite that fact, all four tires seem to be badly chopped and caused vibration at any speed over 50 mph. Tire rack has refused to do anything for me, and of course Michelin is blaming the car. Screw them both, they'll never get another dime from me.
    question is, which tire should I buy now? I've heard good things about continental DWSO6, but I'm wondering if I shouldn't just get dedicated winter tires instead. Problem is, I have another 2 months of relatively dry pavement, but with temperatures below 40, so I can't use my summer tires. Can I drive winter tires in a spirited manner? Or will driving them on dry pavement just ruin them?
    spyder57 thanked this.
  2. Si_chRis
    Si_chRis Senior Member
    Jul 10, 2017
    80
    71
    Connecticut
    2000 Honda Civic Si, 2018 Honda Civic Type R
    I had the Continental DWS06. I ran a 235/45/R18 and the ride was comfortable, minimum road noise, good in the rain. They were great in the dry as well but cornering felt mushy since the sidewalls were on the softer side. Definitely a great daily driving tire.
    I actually just dismounted my tires, if you're running an 18" wheel no wider than 9", I have them listed for sale in the member classifieds: https://www.civicx.com/threads/connecticut-continental-dws06-tires-235-45r18.42275/
  3. OP
    davemarco
    Jun 3, 2017
    2,136
    1,209
    New York
    Thanks for the heads up. My winter wheels are Motegi 19" unfortunately.
  4. Si_chRis
    Jul 10, 2017
    80
    71
    Connecticut
    They do make the Continental DWS06 in 19" so they are an option for your Motegis.
    To add on the winter tire question, driving spiritedly will generally suck. I actually had dedicated winters installed onto the wheels that I dismounted the Continental DWS06s from, and drove on them for a couple of days this past week when it was in the 60s as I was waiting for another set of wheels and tires to arrive from FedEx. Bascially, steering inputs will be delayed and you will feel like you are driving on marshmellos. You will practically have no confidence in cornering, and the traction control light will constantly be on if you give it a little gas. It is just the nature of winter tires in warmer weather. I immediately took them off once my other set of wheels and tires arrived. I will swap my winters back on once it gets real cold. As long as it is under 40 degrees, winter tires should wear normally in wet or dry pavement. If it gets warm above the 40s, they wear much faster.
    davemarco thanked this.
  5. TheSnakeJake
    TheSnakeJake Senior Member
    Oct 10, 2018
    65
    Cincinnati
    Jake
    CTR
    I would get a dedicated winter set. I run the falken eurowinter and they are fantastic. I've been running this tire for 3 years (golf R, focus RS, typeR) and they really perform very well for a winter tire. The handling obviously isn't like an ultra high performance summer, but you can certainlty drive spirited with these. Highly recommended and they are pretty cheap.
    https://www.falkentire.com/tires/car-tires/eurowinter-hs449-tire
  6. HRace
    HRace Senior Member
    Feb 24, 2018
    251
    156
    United States
    Honda Civic
    I've run 4 sets of performance snow tires now (various cars in the past) and 2 sets of regular snow tires. I can't go back to regular snow tires now. The performance snows are very good at avoiding the squishy tread block feeling. They also benefit from not wearing down as fast as snow tires when driven during non snow conditions.
  7. speedvagen
    speedvagen Member
    Mar 28, 2019
    Ohhhh!
    sgp fk8 #r-26236
    Whoa, I’m having issues with my AS 3+ i had installed about 1000mi ago too. I’ve been trying to narrow down whether it’s the tires, the engine that seems to vibrate the hood into movement just resting at a stoplight, or something else.....it seems to start up around 40mph, and yet, strangely enough, settle back down until 75mph...
    wonder if there was a bad batch or something. I’ve had them balanced 3x now
    ‘vagen
  8. Driveitlikeuboughtit
    Driveitlikeuboughtit Senior Member
    Jun 28, 2018
    820
    536
    2018 CW CTR
    Get some Hakkapelliita's, own the icy roads.
    If you paid with a CC, look into whether you have a CC warranty.
  9. OP
    davemarco
    Jun 3, 2017
    2,136
    1,209
    New York
    Have a tire guy check to see if they have cupping/chopping/feathering.
  10. Mark11
    Mark11 Senior Member
    Oct 7, 2019
    151
    76
    2019 Vic
    #10 Mark11, Oct 19, 2019
    the stock tires,
    you wouldn't be having these problems and would have saved a bunch of money
    people always seem to think something different is always better.....until.....well.....it isn't
    what did these tires do for you that the stock tires could not do?
  11. 87elco
    87elco Senior Member
    Oct 25, 2018
    1,212
    457
    Jersey/Virginia
    Tj
    1987 el camino ls swap, 18 civic 6speed, 86 Porsche 911 (euro spec)
    Warranty on those Michelins ? Or are they staggered setup (no warranty)
  12. 87elco
    Oct 25, 2018
    1,212
    457
    Jersey/Virginia
    Tj
    I have then on my 911 they are seriously some sticky shit...I like the new general as05? I think not sure but they are great
  13. OP
    davemarco
    Jun 3, 2017
    2,136
    1,209
    New York
    #13 davemarco, Oct 19, 2019
    Drive in snow, you sanctimonious donkey.
    I have the stock tires and run them in warm months. Some of us live in climates where the temperature drops below 40 degrees. :doh:
    UberCivic thanked this.
  14. OP
    davemarco
    Jun 3, 2017
    2,136
    1,209
    New York
    I am told that "cupping" isn't covered by the warranty, unfortunately. Even though I have documentation that the alignment is/was perfect and the tread is still practically new.
  15. 87elco
    Oct 25, 2018
    1,212
    457
    Jersey/Virginia
    Tj
    I would try a different store
