schmiddr2
- Apr 3, 2018
- 13
- 152
- 84
- Nashville
- 2016 EX-L
So far I'm pretty happy with the car. Good road manners, not too loud, and I'm averaging about 37mpg. This is a work car I drive a lot, so it's time to upgrade. I like the HU and it's tied into everything so I'm going to keep it.
My plan so far: High level signal --> MS-8 --> 900/5 --> GS60 and 3" mids.
No tweets - I've lived without them just fine for years. I'd like to put the 3" in the sails and I've already bought a spare set of sails to work with. I'd like to hire this out, but I will probably end up doing it myself due to time and logistics.
So I've started the install and found a good place for the DSP and amp. Removed the rear speakers and used some of the exiting threaded holes (M5 screws).
I used two 9 conductor cables. One to get front 4 speaker signal + REMote turn on to MS-8, and other to get 900/5 signal back to speakers . Pretty easy wire routing so far.
So once I got the cables to the front I realize there is no amp behind the passenger kick panel. I was under the impression from all my reading that there would be. So, I guess my next step is to check continuity from the radio speaker harness over to a speaker and see if it is amp-less or not. I guess it doesn't really matter, the signal will still be screwed up and probably have volume dependent EQ. Hopefully the MS-8 can fix some of that.
