Where did you mount your radar detector in your Civic Si?
Civic_Si_Yes
High Speed Low Drag
Riverside, CA
2018 Civic Si Sedan
hey everyone,
I've been searching around looking for the best spot to mount my radar detector (hardwire) that's clean and out of the way.
Because it's a-Si, there's no power mirror so can't use a mirror tap for power. The cable must come from the bottom of the dash or from above. I'm tired of using the coiled 12v cord and want to hardwire it but can't figure out where it should go without getting in the way or without having wires everywhere.
so how did you install yours? pictures would help.
If you used an after market mount, which one was it?
I have a uniden R3 detector and the mounts that come with it suck FYI.
thanks!
kperalta
AluminiumCivic
Colorado
2016 Honda Civic Touring
hey everyone,
thanks!
Blendmount makes excellent mounts that attach to rear view mirrors. They're pricey, but they're awesome. Also, keep your radar detector in the center of windshield. It doesn't work very well in other places. You can also purchase a wire hinder if you really want, which is really just a fancy piece of plastic that adheres to the windshield and holds the wire.
Take your A Pillar off, there's an 8mm bolt under the airbag sign on it. Then, just pull it towards you and it comes off. You can pull the headliner down slightly and tuck your wire in there. Down the A-Pillar, zip tie it to the wire in there, and then it'll easily be near the fuse box for hardwiring.
ITGRAD
Love my Civic!!!
Kevin
Alabama
2016 Honda Civic Touring and 2015 Lexus CT200h
hey everyone,
thanks!
Blendmount
Honda Civic 10th gen Where did you mount your radar detector in your Civic Si? 620079D3-34C2-412D-87E4-AF3E55DC1215
Honda Civic 10th gen Where did you mount your radar detector in your Civic Si? 689592C3-7858-4BCD-AD43-D26417FC68C7
Civic_Si_Yes
Civic_Si_Yes
High Speed Low Drag
Riverside, CA
2018 Civic Si Sedan
I just have mine sitting on the dash. Wire just runs over the dash to it. Easy to remove. Works well in that position. Escort Max.
Photos?
Civic_Si_Yes
Civic_Si_Yes
High Speed Low Drag
Riverside, CA
2018 Civic Si Sedan
consultadrone
Pittman
Southern California
2017 Civic Touring Coupe
I hardwired from the fuse box at the driver side kick panel. Ran the cord up the A pillar and under the headliner. Detector doesn't dip down into my field of view through the windshield and is still plenty visible and well within reach. Tucks away nicely when I need remove the detector.
Honda Civic 10th gen Where did you mount your radar detector in your Civic Si? radar
Civic_Si_Yes
Civic_Si_Yes
High Speed Low Drag
Riverside, CA
2018 Civic Si Sedan
Yeah I’m thinking about doing this same setup with my uniden. Not going to spend $100 on a blendmount so the suction cups above the mirror with a hardwire kit should do the trick
Civic_Si_Yes
Civic_Si_Yes
High Speed Low Drag
Riverside, CA
2018 Civic Si Sedan
Hardwired like others and just used the stock suction cups from my R3. Works like a charm and hardly notice it both inside and out.
Honda Civic 10th gen Where did you mount your radar detector in your Civic Si? UNADJUSTEDNONRAW_thumb_3c92
jtrader
OH
What do you and ITGRAD have behind the mirror? ...cylinder shaped. Dash cam?
ITGRAD
Love my Civic!!!
Kevin
Alabama
RepyT
Almost Stock ‘19 R on 255/35-19”
Dave
Destin, FL
2019 Civic Type R FK8, 2017 Lexus GX460 Luxury
Blendmount (Amazon) with Escort 360 Max & M-1 Dashcam (BB combo) tapped to double an existing fuse slot. Used Escort Remote touch switch harness (from Escort) Velcro’d Wired remote under left side steering wheel for no viz green light while driving but close touch silencing). Tri-view clip on blind spot mirror (Auto Zone).
No fuss, no visible wires across view or getting caught. Easy to run them behind edge of headliner, behind A-pillar door molding., behind Left lower trim panel.
Rock solid, can remove mount links for diff positions, I went high & tight.
Whoever says they’re OK with suction cup or any other type mount will not regret spending $ for Blendmount, I was sorry I spent time and effort on other mounts once this one was installed.
Be sure to carefully follow install instructions, order of tightening matters, Firm spring clip is their magic. Phone jack power connector makes unclip easy for mil base entry (it stays up but disco’d power easily seen through windshield).
This rack is much more subtle not lit up and zoomed in.
Honda Civic 10th gen Where did you mount your radar detector in your Civic Si? 10DE6C61-60FA-4D33-B4C5-B1B54238F2DB
Honda Civic 10th gen Where did you mount your radar detector in your Civic Si? 03E82604-C4B6-499B-81B0-13FCB898810C
Honda Civic 10th gen Where did you mount your radar detector in your Civic Si? 152AB81D-501B-4090-BB53-2B11DDF1E36D
Honda Civic 10th gen Where did you mount your radar detector in your Civic Si? 55F87A1F-2E68-45A6-BC94-1E2B54187F5A
Honda Civic 10th gen Where did you mount your radar detector in your Civic Si? 84226ECE-F9EA-4248-900D-19F60217DFDF
Honda Civic 10th gen Where did you mount your radar detector in your Civic Si? 81A4371A-E86E-4ACB-9D2D-C62879D6AC46
