Titan7 Track Wheels : Civic Type R FK8
DA1286
Daniel
New York
Civic Type R
Hey guys, just installed my set of 18” +45 titans with 255/40/18 PS4S. They look great but I noticed my steering wheel being slightly off center to go straight. Car was driving straight as an arrow right before the switch to the Titans. Any idea what this could be? Did anyone need an alignment after installing their titans?
r712
FL
2017 Civic Type R (FK8) | 2017 Fit (GK5)
Assuming you didn't do any suspension mods at the same time (springs/coils), you typically shouldn't have to get an alignment. The only alignment I needed was after I installed springs, but I did that before I installed my Titans.
DA1286
Daniel
New York
Civic Type R
Thanks for the input. I have heard the same- that an alignment isn’t really necessary unless you change height. That’s why I didn’t have it done with the wheel install. I would think the offset would change the geometry up a bit but I guess not.
I’m wondering if it’s one of the tires, or if I just hit a pothole beforehand and didn’t notice the alignment being slightly off with the stock wheels. When I look under the car, the back wheels do not look like they’re pointing in the same direction. The steering wheel is literally like 5 degrees off, but it’s enough for me to notice it. I have to keep tilting it over to move straight, especially at high speeds. Didn’t have time to go back to the shop for an alignment today but will be going tomorrow morning.
Any other insight is appreciated guys. Here are a couple shots:
Honda Civic 10th gen Titan7 Track Wheels : Civic Type R FK8 4ADD5964-3C18-4E4F-A503-7F480F0458F5
Honda Civic 10th gen Titan7 Track Wheels : Civic Type R FK8 2E9D8832-D969-41B7-B9F5-6E9D523B2BBF
r712
FL
Yeah I had my alignment checked when the tire place mounted my new wheels, but nothing was out of the ordinary (except the added camber from the spring install). If you remember hitting any large potholes on the old setup, you might want to get the alignment checked out anyways.
DA1286
Daniel
New York
Civic Type R
Went today, front left toe was 21 degrees compared to 12 on the right, which I guess explains why the car was pulling to the right (too much toe in on the left side). Feels good now, they got the toe down within spec on both sides, front and rear.
nickjohn35
Cincinnati
Current: 2017 PMM Typer R. Former: 2004 350Z
Finally got my 18x9.5 +45 Satin Titanium T-S5s on today! Rubbers are 265/35/18 Michelin Pilot Sport PS4s. Lug nuts are Titan7 O.W.L. Titanium Race nut in Onyx Patina. Center caps on their way. Stock suspension as of now. Plan on Eibach Pro-Kit soon....
Honda Civic 10th gen Titan7 Track Wheels : Civic Type R FK8 984346B9-C0AB-4A35-BA14-612CA8257D97
Honda Civic 10th gen Titan7 Track Wheels : Civic Type R FK8 2B7516F3-584D-4642-88E5-2D5EF52ACE67
Honda Civic 10th gen Titan7 Track Wheels : Civic Type R FK8 F57D25AF-F1DD-4212-8AE1-42AD6CEC7F65
Honda Civic 10th gen Titan7 Track Wheels : Civic Type R FK8 1F5F25C8-C159-485A-8B1A-99D4DB83B7F4
Honda Civic 10th gen Titan7 Track Wheels : Civic Type R FK8 17BD6619-6248-4335-95E5-B7473D51FD96
Honda Civic 10th gen Titan7 Track Wheels : Civic Type R FK8 E63F4209-7ECD-4F8A-90C4-557761167B56
Firthy13
Michael
Newcastle, Australia
CW CTR
I always though machine black looked better on PMM but after seeing this, i much prefer this. Looks great. How do you like their wlug nuts? As far as I understand they are not locknuts are they?
nickjohn35
Cincinnati
Thanks! Trust me, I went back and forth between satin titanium and machine black for months. I couldn’t be happier with the satin titanium. I love their lug nuts. Seriously light as a feather. All 20 weigh 15.5 oz. (0.8 oz per nut). All 20 stock weigh 3.1 lbs. (2.4 oz per nut). No, they have no lock nuts.
Firthy13
Michael
CW CTR
Wow, that is so light! Im still tossing up whether to go satin titanium or machine black on my CW CTR. Will definitely order their nuts as well when I finally make up my mind.
DA1286
Daniel
New York
Civic Type R
Hey guys. Anyone have a trick for getting the center caps to fit? I feel like anytime I change a tire and take the center cap off after initial installation, it doesn’t go back in completely- like the O-rings are now too loose and getting in the way. Anyone have the same issue or ever find a solution?
OMGSIIK
Albany, NY
2005 S2000, 2018 Type R
Had the same issue with one of the caps. I just removed the one o-ring that was loose and so far it has held up.
DA1286
Daniel
New York
Civic Type R
will try this, what ring did you remove? The one further back?
MstrSHAKE
Adrian
SFL
'19 CW CTR
Titan T-R10 in Bronze. 18/9.5 45 mm offset. Winter tire setup, Goodyear Eagle F1 All Season. 255/35/18.
where can I find bronze at? ahhhhh
HRace
United States
Honda Civic
Titan 7 website shows the +45 offset still available to order in techna bronze. Not in stock but their wait time usually isn’t so bad (1-2 months).
