Arcam
- Eddie
- Feb 15, 2019
- 2
- 88
- 27
- UK
- 2018 CTR
Having just done 4 days at the Nurburgring 2 wet and 2 dry I found that the coolant system is woeful, as on the 2nd lap of the 'ring in 18c heat the coolant temp gauge was at 75% max, still amazed that Honda did not include an oil temp sender as standard!
Anyway, zero oil or water consumption but I would like to throw 2 questions out to those who track their cars:
1) I get a "squeak" on lift off from the power at high RPMs (5k+), I suspect it is exhaust or engine mount related, anyone else had this and found the fix?
2) When getting back on the power after braking for a corner and with the RPM still around 4k the throttle/engine response was very flat even with the pedal buried, I run 99oct fuel and the boost gauge showed 1.5bar, air temp 18-20c, 70% humidity, I did not have issues on the 2 wets days, guess with the IC and coolant rad getting sprayed with water every second helped! I don't want to start replacing the IC and rad just yet, has anyone tried this kit and if so did it help?
https://www.ebay.co.uk/itm/FOR-2016-18-HONDA-CIVIC-10TH-GEN-BLK-JDM-CTR-STYLE-FRONT-HOOD-GRILL-EYE-LID/372569475102?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D80d0a5d35a7747dc9a74915dc31aabc3%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D283444493713%26itm%3D372569475102&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3A0560be55-7fc2-11e9-8243-74dbd180061c%7Cparentrq%3Af4879fbe16a0ac3c13f80cd8fff27629%7Ciid%3A1
