AvailableUsername
- May 7, 2021
- 0
- Michigan
- 2017 Civic Hatch Sport Touring
When I went to do another routine oil change yesterday I noticed that there was some oil on the aluminum access panel. The oil seems to be coming from between where the trans mates to the engine. The little black access cover that let's you look at the flex plate was a bit wet. After seeing this I started poking around some more and found what looks to be my front crank seal leaking? Also saw some oil weeping out near where the passenger CV axle comes out of the trans. Here's a bunch of pictures just wanted to see if anyone else has seen anything similar. I saw some threads on the type R forum but this is a CVT not 6MT (hatch sport touring) 75k miles so no warranty
Also noticed the passenger side NVH pad thing on the belly pan was all messed up (first time the belly pan has ever been removed). It's wet because I rinsed it off, gotta love dirt roads...
Ive cleaned things up and will monitor for now. To be honest I don't regularly check the oil level between changes but I'm going to keep an eye on the dipstick level also. Things were dry underneath last oil change (probably not by the crank pulley though that one is a bit more out of sight) I change oil every 5k.
