sbaugz
- Steve
- Feb 22, 2022
- 0
- wisconsin
- 2016 civic
Having issues with my climate control. 2 years ago my condenser died and was replaced under warranty. This past summer my air conditioning started having problems again. It would not get cold. I decided to wait until next summer. Now I am also noticing problems with heat in the winter, so I am thinking that its not actually the condenser, but a bigger problem. The vehicle is currently NOT under warranty. trying to see if I can diagnose and solve on my own.
Here is what its doing: If I put the temperature on auto- it does a fairly decent job of maintaining a temperature by adjusting the fan speed. On the other hand, if I set a temp and use any setting but auto, it literally blasts out super hot air. I can turn it down to 67 degrees and it will still blast out super hot air. under the auto setting, it seems to be pretty hot air as well, but at least the fan speed auto adjusts down to low.
When I play around with the temp settings it stays super hot from Hi all the way down to about 66 degrees. Then once I set it lower than 66 degrees, it gets a little cooler but never cold like air-conditioning.
Hopefully this makes sense. I followed a post for checking the diagnostics and it didn't seem to pull any codes although the instructions I used didn't seem to fully apply to my vehicle. Mine is an EX-L
thanks.
thanks.
