Bowsy
- Mar 7, 2021
- 2
- Netherlands
- Civic X Sport
I found several threads about wind noise, and indeed similar symptoms to what I experience.
But none brought full closure, so I hope this thread can help resolve my issue and also be a useful reference to other folks in future.
Looking for some ideas to tackle an annoying wind whistle.
Recent new owner of a lovely Civic X Sport, 2017. (Hatchback, made in Swindon UK)
The only problem is a high whistle that kicks in around 120km/hr+. Above 150 its really loud.
It sound seems to originate on the A frame just above the side mirror area on the passenger side (EU). Right above the small interior speaker.
I noticed it on the test drive and figured I could systematically figure it out, but I am running out of ideas.
Here is what I have tried so far:
I have read that Honda have released a revised door seal to tackle this issue. Can anyone confirm this is true and if so what is the part number?
Appreciate any creative ideas to help find this gremlin.
- Tape up the areas all around the passenger side (around wing mirror, trim, door, windscreen)
- Added foam tape to the edges around door and chassis.
- Leak finding test using internal smoke tester --> Seemed to lose some smoke around the wing mirror (I thought I found the smoking gun here)
- Remove wing mirror, tighten up the 3 mounting screws and added silicon around the mounting area (Smoke test now ok)
- Taped up small joins/gaps/edges in the mirror itself
- Carefully added black silicon around the outside trim areas around the mirror mount.
- Increased area of sealing tape (basically full semi circle around the windscreen, further down the door)
- Added 'creping crack cure' around the edge of the windscreen
- Added extra 'D shape' rubber seal to edge along top of door and roof
- Im quite sure its not the turbo or AC as the noise is audible at the edge of interiour trim and window, dependence is only on speed and wind direction, not throttle or anything else.
- The rubber seals around the door and windows are all flush in situ and have no obvious damage.
- The orientation and fit of the door to body appears to be well aligned (flush with no obvious tilts or gaps)
- The direction of the wind does change the tone/pitch of the whistle.
- Folding in the mirrors while driving does not have any discernable difference to the whistle.
- The sound does not appear to be coming from the airco grating. When inside the sound can be fully muffled by putting a rag just above the speaker and against the window.
- From the inside of the car, the gap between the door trim and dashboard, is visibly bigger on passenger side than driver side. At least 5mm. Not sure if this is typical.
