Flashpro
Addaj2707
Castle Rock
2017 honda civic si
Flashed my 2017 si went smoothly then after driving for a while all the dash lights came on. Do I have to drive it around for them to clear or reflash.
Davsonamission
David
17 Civic Si Coupe
Firstly there is a Ktuner/Hondata thread in the subforums you might want to check or post this in.
I used a Ktuner so I am not familiar with the Hondata unit. All I know that during the flash process you will get a lot of the lights flash up when the stock ECU map is being erased, but they will go away once the new ECU map is uploaded. You might want to consider reflashing the ECU back to stock and see if the issue is corrected. If that does the trick then reflash the ECU to the map you want.
dallasjhawk
Royse City, TX
check your codes, if no codes, flash stock and see if they go away.
Addaj2707
Castle Rock
2017 honda civic si
Thank you I reflashed and it's all good
