ENKEI TS5 18/9.5/R18 +45 & 245/40/R18
chomdh
Iowa
2021 CTR, 2004 S2000, 2006 TL, 2016 Outback 3.6
Use Honda NA2 NSX center caps. They will fit perfectly :)
https://www.mitamotorsports.com/nsx-accessories/02-center-cap
Quantum Grey Metallic is the same color. It'll be a white Honda logo.
Thanks I will keep that option in mind. Right now I’m set on using the oem fk8 center cap but nice to have options. Plus I have a 3D printer and some quantum gray paint to make the adapters match the wheel color. Once I get tires installed I’ll take more full car pictures and post in my own thread about these sweet Mita y wheels.
Stickyyhands
Collin
CT
2021 civic type r
Mita Y wheels 18x9.5 +45 with Michelin pilot sport all season 4 ZP 275/35 tires. I’ll do the other 3 when it cools down. It’s about 100 deg F in my garage rn.
Looks great man! I just ordered some ps4s in the same size with the same dimension wheels. Have you had any rubbing? I'm on stock suspension, assuming you are as well
chomdh
Iowa
I ended up returning those tires since they were “ZP” run flats but not advertised as such. I didn’t want the extra tire weight or ride harshness that comes with run flat tires. So I can’t say about rubbing. I believe someone said they can rub with a full car load over big bumps and in r mode.
just today I ordered Dws06+ In 265/35 because the regular ps as4 non run flats are on back order for ???? According to tire rack specs the 265 Dws06+ has only 0.1” less tread width than ps as4 275. And I don’t want to rub ever.
I’m also pleased at the weight of the 265/35/18 Dws06+ which will give me about 42 lbs each wheel and tire combo for abouta 10 lb reduction per corner compared to stock wheel and tire at 52 lbs.
chomdh
Iowa
Ended up with 265/35/18 dws06. Will mount the other 3 soon.
Honda Civic 10th gen ENKEI TS5 18/9.5/R18 +45 & 245/40/R18 9DA21B05-D966-478C-9F9C-8D02584D7148
Russm8
Russ
Uk
Fk8 type r
Hi all.
Have some 18 enkei wheels on way +45 9.5
What will give zero rub. Will the 265 35s or would it be safer to run 245 40s.
I've read so many forums I can't decide.
Really appreciate any replies
Redman920
Dustin
Green bay wi
2017 civic si coupe
Just purchased a set of vr forged d03 -r. They r 18 x9.5 +45 offset. I'm on whiteline springs. I auto cross/ cruise alot. Will I ne safe with 265 35 r18s to not have rubbing issues?
BoostedDreams
Heisenburg
South East Florida
2019 Type R, 2006 Mazda 6
You’re good.
