i read on here someone said it was ok though even if you floor it alotIf you don't know what it does, you probably shouldn't disable it.
It's there to protect the turbo from over-spooling in the upper RPMs. On stock turbo and fuel system, it's best to not touch it unless you're logging and can validate there are improvements with a dyno.
That's what the PA table is for when you're dealing with different altitudes. Pretty sure it doesn't deal with over speed, just keeps exhaust temperatures in check since higher boost on the tiny turbo will make the charge too hot to have any benefit of the added pressure. Charge air rises in temperature a lot as is is with it enabled.If you don't know what it does, you probably shouldn't disable it.
I believe those PA tables were set pretty high by default. Above 30 psi?That's what the PA table is for when you're dealing with different altitudes. Pretty sure it doesn't deal with over speed, just keeps exhaust temperatures in check since higher boost on the tiny turbo will make the charge too hot to have any benefit of the added pressure. Charge air rises in temperature a lot as is is with it enabled.
Though I am interested in trying it again now that I'm catless. Whenever I can get my 2020 jailbroken
is it better if your car is at high altitude or doesnt matter?That's what the PA table is for when you're dealing with different altitudes. Pretty sure it doesn't deal with over speed, just keeps exhaust temperatures in check since higher boost on the tiny turbo will make the charge too hot to have any benefit of the added pressure. Charge air rises in temperature a lot as is is with it enabled.
i guess tuners have no idea what they mean either since they all turn this function on when they take it in for a tune,I believe those PA tables were set pretty high by default. Above 30 psi?
OP has no idea what any of these tables mean. If you don’t know what they do, then you shouldn’t change anything. That’s my opinion but people can do whatever they like with their car.
For exhaust temperatures? Doesn't matter. Just at a higher altitude the air is thinner so the ECU will compensate to protect the turbocharger from over spinning through the thinner air.is it better if your car is at high altitude or doesnt matter?
There's a fundamental flaw in the way you think.i guess tuners have no idea what they mean either since they all turn this function on when they take it in for a tune,
i bet these tuners barely make much change at all going off hondata tunes.
I enabled it and saw a huge amount of power in the low end, seems to be better to me. I will most likely put it back to stock , on the track it seem to struggle at higher speeds at, basically not as smoothe.For exhaust temperatures? Doesn't matter. Just at a higher altitude the air is thinner so the ECU will compensate to protect the turbocharger from over spinning through the thinner air.
Sea level is always the best for power, but turbocharged engines are great for higher altitude. For example much like how they started putting them on war planes in WW2, especially bombers so they could fly higher (and faster) and avoid AAA.
To the OP, I personally don't see the point of doing it on the stock turbo. Hondata even states that more boost doesn't equate to more power (with stock turbo) especially at the top end. The last point is what I go by. Long 5th gear pulls generate a ton of heat. If you're worried about it being dangerous? Not that I know of. The feature was added while prl was testing their prototype turbo and hit a wall where they couldn't get above 400hp, with egt disabled they could.
Placebo maybe? It's purpose is to increase air charge in the top end, I don't believe it does anything down low.I enabled it and saw a huge amount of power in the low end, seems to be better to me. I will most likely put it back to stock , on the track it seem to struggle at higher speeds at, basically not as smoothe.
Just by driving the car I do not think this is safe above 130mph to leave on ,
weird down low there is a huge improvementPlacebo maybe? It's purpose is to increase air charge in the top end, I don't believe it does anything down low.
