Nothing better than a K, in light chassis last summer was fun, I ran a Bentley Continental GT worth 200k, he was rattled!The 99-00 in Pepsi Blue was a great little car. I'd still rock one in 2017
The thing I like most about the 06-11 was the K20. Great motor
That's absolutely beautiful. Seems like a really clean engine swap as well.Nothing better than a K, in light chassis last summer was fun, I ran a Bentley Continental GT worth 200k, he was rattled!
Jesus. That's a great amount of power for something that light. How's your experience with skunk2 products? In my searches for parts they always come up and I'm yet to try them out. Also, what tires do you run?Thanks, she was a full bolt on k20z1. Tsx /z3 cams, skunk2 intake street mani, ktuned header, 2.5" straight pipe to a vibrant muffler. It also had a type R trans, it was wild,, made 250whp by Joe at Altech preformance in Toronto. Miss it, I hope the CTR might pull almost as well as that car did..
The Si has a "SPORT" button that replaces the "ECON" button on non-Si models.Have you checked the steering parts? I believe the documents state that the Si has different driving modes and steering is affected as part of the driving mode changes.
Thanks. But what is the "variable ratio" steering that keeps getting quoted?The Si has a "SPORT" button that replaces the "ECON" button on non-Si models.
On non-Si models, turning ECON on reduces throttle mapping so it takes more physical pedal movement to open the throttle blade to encourage smoother and more fuel-efficient driving which makes the car "feel" less responsive (wide-open throttle is not affected).
On Si models, turning SPORT on increases throttle mapping so it takes less physical pedal movement to open the throttle blade, which makes the car "feel" more responsive. It also reduces the amount of assist provided by the electric power steering system making the steering more firm and improving feedback. The third thing it does is energize a solenoid valve in each damper resulting in more resistance to fluid flow which firms up the suspension.
Skunk2 is fine. No issues. I personally like Dunlop tires. Fusion makes good cheaper tires as does General imo.Jesus. That's a great amount of power for something that light. How's your experience with skunk2 products? In my searches for parts they always come up and I'm yet to try them out. Also, what tires do you run?
Variable ratio steering is similar to standard rack-and-pinion steering, except the spacing of the teeth varies along the length of the rack. By having closely-spaced teeth in the center of the rack and widely-spaced teeth towards the outside of the rack, you can have both precise, easy, on-to-near-center steering feel and fewer turns lock-to-lock. It's been around for over 40 years.Thanks. But what is the "variable ratio" steering that keeps getting quoted?
Are you sure about the electric power steering providing less assist in sport mode? I'd be overjoyed-- my father's Buick Regal GS just stiffens the steering in the GS mode and it feels even more fake than the normal and Sport modes.The Si has a "SPORT" button that replaces the "ECON" button on non-Si models.
Got it. I went back and looked through the press release for the 10th Gen Civic and the Si and Type R. It appears they all call out variable ratio steering. In the Type R it says it's retuned. i don't see anything specific about changing the ratio being different.Variable ratio steering is similar to standard rack-and-pinion steering, except the spacing of the teeth varies along the length of the rack. By having closely-spaced teeth in the center of the rack and widely-spaced teeth towards the outside of the rack, you can have both precise, easy, on-to-near-center steering feel and fewer turns lock-to-lock. It's been around for over 40 years.
If you're referring to the Buick Regal GS from 1997 to 2004, it used a system called MagnaSteer which was basically an electromagnet wrapped about the steering shaft. It was used in addition the hydraulic power steering system and could provide either additional assist or resistance to steering input depending on the speed of the vehicle. At low speeds, it helped to turn the steering wheel. At high speeds, it provided a resistance to steering effort. Since this resistance was provided by MagnaSteer instead of road forces and vehicle geometry, it felt...fake. Given the demographic of most Buick buyers, they were unlikely to know or detect the difference. DISCLAIMER: I bought a brand new Buick when I was 26.Are you sure about the electric power steering providing less assist in sport mode? I'd be overjoyed-- my father's Buick Regal GS just stiffens the steering in the GS mode and it feels even more fake than the normal and Sport modes.
Exactly. My father's is a 2012, and as soon as he got it, he commented how typical of GM the overboosted power steering was. All the times I've driven it, I notice a few things I cannot stand, namely the absolutely awful 2nd gear synchro which makes anything but granny shifting impossible, the clutch is dead and very assisted, the electronic throttle, and the electric power steering in GS mode. After about 2 o'clock, the electric power steering stiffens up (but does not reduce assistance, it basically adds fake resistance) and it feels absolutely horrid. I also noticed this at Bondurant when I drove a 2015 Camaro SS on track for a week. I barely had any road feel, albeit that was still a fantastic time. The most raw experience I've ever felt was in a 90s Miata I test drove. I know it's in a totally different caliber of car, but the steering feel was immaculate. More and more cars I drive now feel unbelievably cushioned and fake behind the wheel, and if the Si really does just reduce power assist in Sport mode, I'll be quite pleased, because that's a true enthusiast move by Honda.If you're referring to the Buick Regal GS from 1997 to 2004, it used a system called MagnaSteer which was basically an electromagnet wrapped about the steering shaft. It was used in addition the hydraulic power steering system and could provide either additional assist or resistance to steering input depending on the speed of the vehicle. At low speeds, it helped to turn the steering wheel. At high speeds, it provided a resistance to steering effort. Since this resistance was provided by MagnaSteer instead of road forces and vehicle geometry, it felt...fake. MagnaSteer was a form of electric power steering, but it was not poweful enough on its own, so a conventional hydraulic system was used in conjunction. Given the demographic of most Buick buyers, they were unlikely to know or detect the difference. DISCLAIMER: I bought a brand new Buick when I was 26.
When electric power steering systems came along, they opened up a whole new world of driving features that could be enabled just by changing the software. Instead of "artificially increasing road feel" by resisting steering input, they simply reduce the amount of assistance provided to increase road feel.
Of the dozens of vehicles I've owned, I've had two without power steering: One was a '71 Ford pickup. It was almost impossible to drive without having to visit the chiropractor the next day. The other was an '84 Fiero. Since the engine was in the rear, there wasn't much weight over the front wheels. The steering feedback was good (for the time).The most raw experience I've ever felt was in a 90s Miata I test drove.
