dt10g
- Nov 30, 2015
- 17
- 883
- 624
- Canada
- 2016 Civic LX sedan 6MT (Canadian)
Summarizing all available hoods for the 10th Gen Civic...
will update as more products are located.
Please contribute suggestions to this body of knowledge.
If there is any manufacturer who does NOT want their product featured, or requires that any information be corrected, then please send me a PM and I will update your listing ASAP. Thank you!
Note: Civic Models interoperability
All 10th Civic hoods should be compatible between all models - Hatch, Sedan, Coupe with the following exception:
The FK8 Civic Type R (CTR) hood latches are located in a different position ... and while FK8 hoods should "fit" FC/FK vehicles... the user would need to address the latching in some way. This may require engineering/fabrication to the latch or latch mechanism and/or use of additional hood pins. Any modification will not be supported by manufacturers. Recommend users follow all manufacturer guidance at all times.
Also, note that hood pins may be required equipment on some aftermarket hoods, if they do not have the structural integrity to retain the hood via the hood latch alone. (e.g. If the latch rips out of your carbon hood while you are doing 70mph on the highway, bad things may happen...) Again you should follow all guidance provided by each manufaturer - manufacturers will document whether hood latches are sufficient or not.
Note: Construction
Please evaluate each product yourself regarding construction...
Some may be 100% (wet/dry) carbon, others may be FRP or a combination of the two.
Each product has pros and cons and one is not necessarily better than another in all cases.
Some products may require painting while other products may be UV protected for exposed use.
FRP = a composite material comprised of carbon fiber reinforced polymers.
Any stated weight specifications are those provided from the manufacturer.
One should naturally expect some variance in these measurements vs. the product received.
Vented hoods may or may not offer Rain Protection or Mesh Screen inserts, as an included or optional extra.
Brands / Products
in no particular order...
Honda
source: Honda, Auto recyclers, Forums (members who upgraded)
OEM - FC/FK steel hood
weight: unknown
vents: none
steel
OEM - FK8 (CTR) aluminium hood
weight: unknown - approx. 30lbs? Mugen suggests OEM is 9.9 kg (21.8 lbs)
vents: single central scoop
aluminium
CMST Tuning
https://cmsttuning.com
Carbon Fiber CM-Style Hood Bonnet for FK8
model: FK8
weight: 18 lbs
vents: multiple
choice of carbon finishes
Carbon Fiber Glass Transparent Hood for Honda FK8 Type-R and 10th Gen Civic
model: choice of FK8 or FC/FK
weight: unknown
vents: multiple
Carbon / FRP
Carbon Fiber Hood for Honda FK8 Civic Type-R (2017-ON) OE-Style
model: FK8
weight: (choice?) standard 18lbs, Light 15 lbs, Ultralight 11lbs
vents: multiple
Carbon
JS Racing
https://www.jsracing.co.jp/
FK8 Aero Bonnet Type-V
model: FK8
weight: unknown
vents: center + sides
choice of material:
- carbon/carbon
- carbon/FRP
- FRP
JS Racing images state unauthorized reproduction prohibited so you'll have to look it up here...
https://www.jsracing.co.jp/js2/inde...xSHASHU=49&xPARENT=17&xNO=ABV-K8-CC&xKEYWORD=
Mugen
http://www.mugen-power.com
60100-XNCF-K0S0 Carbon Aero Bonnet
model: FK8
weight: approx. 6.0 kg (13.23 lbs)
vents: central + multiple sides
dry carbon
Robot Craftsman
https://robotcraftsman.com
Carbon Fiber Hood Bonnet for Honda CIvic 10th Gen Sedan Coupe Si FK7 Hatchback
model: FC/FK
weight: unknown
vents: 2 center
Carbon Fibre or FRP
choice of finishes
part of a larger widebody offering from Robot Craftsman
Seibon
https://seiboncarbon.com/
Multiple models - FC/FK
model: FC/FK
weight: unknown
vents: various
Multiple models - FK8
model: FK8
weight: unknown
vents: various
Spoon Sports
https://spoonusa.com
60100-FK7-000 Spoon Carbon Bonnet - Civic FK7 MT/CVT
model: FC/FK
vents: none
weight: unknown ("up to half the weight of the factory hood")
Carbon
Synth Carbon
https://www.synthcarbon.com
2016-2021 CIVIC X CARBON FIBER V1 STYLE HOOD
model: FC/FK
weight: unknown
vents: multiple sides
Carbon
2016-2021 CIVIC X CARBON FIBER V2 STYLE HOOD
model: FC/FK
weight: unknown
vents: center scoop + multiple sides
Carbon
Varis
https://varisna.com/products-by-vehicle/honda/
VARIS ARISING-I COOLING BONNET HOOD FOR FK8 HONDA CIVIC TYPE R
model: FK8
weight: unknown
vents: center vent + multiple sides
3 material options:
- FRP
- Carbon Fibre
- VSDC (Varis Semi-Dry Carbon )
Note that there is optional integration with the Varis hood side ducts,
and that this is part of a larger Varis widebody kit offering.
Note the ducts between the hood and the side mirrors:
https://varisna.com/product/varis-carbon-cooling-bonnet-hood-side-ducts-for-fk8-honda-civic-type-r/
Note: Construction
Brands / Products
Honda
weight: unknown
vents: none
steel
aluminium
CMST Tuning
model: FK8
weight: 18 lbs
vents: multiple
weight: unknown
vents: multiple
Carbon / FRP
model: FK8
vents: multiple
Carbon
JS Racing
model: FK8
weight: unknown
choice of material:
- carbon/carbon
- carbon/FRP
- FRP
Mugen
model: FK8
dry carbon
Robot Craftsman
model: FC/FK
weight: unknown
vents: 2 center
Carbon Fibre or FRP
choice of finishes
Seibon
model: FC/FK
weight: unknown
vents: various
model: FK8
weight: unknown
vents: various
Spoon Sports
model: FC/FK
vents: none
Carbon
Synth Carbon
model: FC/FK
weight: unknown
Carbon
model: FC/FK
weight: unknown
Carbon
Varis
model: FK8
weight: unknown
3 material options:
- FRP
- Carbon Fibre
