Battery or Alternator issue
tisuanhoc
Tin
salt lake
civic ex 2016, Accord EX-L 2020
My car started this issue 2 months ago. The battery sometimes dead for no reason after I park for 8 hours at work. I've got to jump to get the battery work. I bring to Autozone to check and they have only 8-10v. That meant my alternator needs to be replaced? My car is civic 2016 EX and 40,000 miles. Anyone has this issue?
PhilF
Phil
South Central Pennsylvania
2020 CRV EX-L Platinum White Pearl/Ivory, 2020 CRV EX-L Crystal Black Pearl/Grey
First I'd get a load test done on the battery, before you jump to the alternator conclusion, my first suspicion would be a 4-year old battery going South. I'd also make sure the battery connections were good and clean. A couple of high resistance (shorted) battery plates will draw down charging voltage.
jayy_swish
Jay
Yeah I hardly doubt it’s an alternator issue. Your battery is more likely to go out than your alternator. Your battery simply just isn’t holding its charge anymore. Did autozone run a load test on the battery?
Hollywoo0220
RJ
WA
Your Civic is 4yrs old now. All the stops and starts, etc have worked the strength of the cells down. Time for another battery.
NHCivicGuy
NH
2021 R
These batteries may test fine too, but they are essentially too small for our cars and have been a known issue even from day 1. In your case, definitely would say the battery has reached it's end.
PhilF
Phil
I've been driving Hondas since the 80's, driven Civics, Accords & Preludes, only outright battery failure was in an 89 Prelude (actually failed at the dealer!) Have replaced a few Civic batteries, usually when my mechanic indicated some weakness during a Multi-Point inspection, the Prelude got a Interstate battery, the few others were always Honda batteries that they warranty for the life of the vehicle. I live in the Midatlantic area, winters are typically not too extreme, sometimes going below zero, but have never noticed a capacity problem. Worked at a hospital for 25 years so car had to start, always did, never let me sit.
tisuanhoc
tisuanhoc
Tin
salt lake
I cleaned the connections and It worked. Voltage displayed full. And I'm going to replace the battery soon. Thank you guys for your help.
86salmon
It's Hedley, Hedley Lamarr!
Chucktown, SC
Just had to do my battery after 20 months. Probably the battery
Jay_Tech
Jarrett
Kawartha Lakes Ontario
2019 Honda Civic Si
Easiest way to check if the alternator is working fine is if you have a charging light on in your cluster(the one that looks like a battery) there is likely a charging system fault. Which is almost always the alternator. Also if you can turn the car on and then put a multimeter between the two battery terminals while it's running it should show between 13.5-14.5 volts. That will tell you the alternator is charging the battery. If the battery tests ok on a load test you may have a parasitic draw(something is putting a draw on the battery) and if that happens to be the case you may need to have a mechanic do an electrical diagnostic.
