2016 Civic Not Starting
ryan714
Buena Park
2016 Honda Civic EX-T
Hi,
I was listening to my radio with the engine off and "Brake System Problem" popped up. I tried starting it but the car's dash just sputters and blinks. There's no turn over but I hear like a tapping noise like it's trying to start.I push the brake in to press the start button and the infotainment screen shuts off as well. Turned off the car and the brake system problem disappeared. Any solutions?Could be a dead battery? This is the first time it's happened. PLEASE HELP I'M STUCK AT SCHOOL.
UPDATE:went back to vehicle to try starting it and brake system oroblem popped,electric brake system problem, and VSA problem popped up. DRLs began to flash and the dash turned off and flashed like battery was dead when starting. The warnings of the problems began to change at a rapid rate
I'd see if you can find someone to jump the car off. Just make sure it's done properly, hopefully that will take care of the issue.
ryan714
Buena Park
Wont be able to do that until 2:15pm, but will be contacting AAA.
Draken187
Connecticut
2013 accord ex-l sedan, 2016 accord sport sedan, 2006 civic type r (in spain) and 2017 civic sedan ex-t w/manual transmission
Ya.. Battery doesnt have enough voltage.. Make sure you take a long drive after the jump
Timothy
TImothy
South El Monte
2017 Honda Civic EX-L Navi
This just happened to me right now and yesterday. First my brake lights were flashing and radio stoped playing. Today which is July 27. my dash and radio turned off, when I say that happen I gave it gas and it came back on. But idk if giving it gas helped. I’ve stalled the cvt before.17 ex-l Navi 30k miles
shoegazer
Raleigh NC
2018 Civic LX Coupe 2.0 (CVT)
Are you still on your original battery? If so... it sounds like it's time for a new one.
ski-line900
Kevin
The stock batteries suck, happened to me on my '18 couple months after I bought it. Dealer replaced
jred721
James
Northern Virginia
'20 Accord Sport
Im pretty confident its a battery issue. Most starting problems or electrical issues I've seen with 10th gen Civics all stem from the battery. Get it tested and check it out, sounds like you should replace it since the OEM ones are insanely weak.
TypeSiR
On a Twisty Road
1.5T Civic, Fit, MX-5, CTR
