- JW
- Jul 8, 2017
- 202
- 98
- Somewhere
- 00 Orion Nebula
- Banned
- #76
I'm only familiar CompuStar and not Fortin, but others in this thread are (Fortin also has a tech support phone number).I’m about to install the Fortin unit on my R, that I had previously on my Si. Is it possible to just tap that CPSS with the Fortin GWR or similar instead of doing the relay? To me it makes sense I could but I’m not an electrician. If not, could you tell me the pins on the relay and what wire would need to go where?
Also, when this is all said and done, does the remote start still throw all the warning lights? I never had this issue on the 2020 Si, but I know the R is different with that CPSS.
And thanks for all your detailed info on GitHub, it’s amazing and I’ve bookmarked it.
For the CPSS wire, it needs to see ground during crank only (negative start output); GWR will not work, as that would emulate the clutch being depressed the entire time the vehicle is running to the VSA MCU.
- When done correctly, it shouldn't throw any DTCs or CELs [Check Engine Light], however I'm unsure how Fortin's Takeover feature works with the CPSS circuit; without Takeover, the BCM still registers data errors if the vehicle is restarted without allowing the BCM to enter sleep mode (~10s) after remote starting (e.g. without Takeover, once the Type R logo disappears from the gauge cluster, it can be restarted)
